THandBrake (formerly Smallx264) is a batch GUI for Handbrake.
--Features
-Select between multiple audio/subtitle tracks or select all
-If subtitle file (srt) with same name as source exists, it can be soft-coded to output.
-Device profiles (Android, iPod etc)
-User profiles
-Preview option
-Portable version available
-Video Filters
-Manual or auto cropping
You can download setup from here.
Suggestions and bug reports are, as always, welcome.
Please note that this program uses the latest HandBrakeCLI build, so there can be problems. You can always download a different build, rename files properly and copy them to the program folder. As long as there are no command changes, it should work without a problem.
Results 1 to 30 of 36
Update:
--0.2.1
-Added: "Level" option (thx to jq963152)
-Added: Option to disable skinning (thx to jq963152)
-Added: "Auto" item for profiles, presets etc (thx to jq963152)
-Added: Balloon hint will show up when encoding is done
-Added: Option to see info about selected file
-Fixed: Problems with video sizes (thx to magsood and detmek)
-Fixed: Preview button was not disabled during an encode
-Updated: HandBrakeCLI to nightly build svn5219 (thx to jq963152) -
Update:
--0.3.0
-Added: "Fast first pass" option
-Added: Menu
-Added: A few minor GUI improvements
-Updated: AlphaControls to 8.17
-Updated: HandBrakeCLI to nightly build svn5243 -
Not exactly.
There a couple of differences but summary is that TX264 offers more options and can encode to aac-he whereas smallx264 was intended to be small and easy.
Personally I use TX264 to encode anime content (x264 10bit+aac-he), for other content I use smallx264. TX264 is also better if you want internal subtitles to be copied to output. And I also don't like HB windows GUI myself.
Update:
--0.6.0
-Added: Options to select between audio and subtitle tracks
-Added: Device presets (Android, iPod etc)
-Added: Auto-update checker
-Added: Update checker will now ask user if they want to visit homepage
-Added: A new progress window
-Added: Total progress will be updated smoothly
-Added: Changed skin
-Fixed: Two pass options were still available even if user selected quality (thx to dlarge)
-Updated: HandBrake to svn5454 -
Update:
--0.7.0
-Added: Option to burn-in internal subtitles
-Added: Sampling rate option
-Added: Popup menu to file list
-Added: About window instead of messagebox
-Fixed: Preview gave "index out of range" error
-Fixed: Preview didn't create proper preview file
-Updated: madExcept to 4.0.7 -
Update:
--0.8.0
-Added: Seperate 32bit and 64bit builds
-Added: Option to select all audio/subtitle streams
-Added: Option to hide/show settings
-Added: When done Smallx264 will give a sound warning
-Added: Audio options, DRC and gain
-Added: MediaInfo will be used to show file info
-Added: A few UI changes
-Added: Passed time will shown during encoding
-Fixed: Closing info window didn't reset info list
-Fixed: Removed "+" from audio/sub track lists
-Fixed: Level option wasn't saved
-Fixed: Samsug profiles didn't set correct resolution
-Updated: HandBrake to 0.9.9 -
Update:
-1.0.0
-Added: Only files with valid duration will be added to the list
-Added: Option to disable audio (codec none)
-Added: "File size" option
-Added: A few GUI changes
-Added: A better handling for disabling skin
-Added: When "Select All" and "Burn-in" is selected, first sub track will be burned
-Added: Option to specify subtitle languages (en,eng,english etc)
-Fixed: "Disable Skin" button was not visible
-Updated: AlphaControls to 8.48
-Updated: HandBrake to svn5863Last edited by ozok; 1st Nov 2013 at 21:03.
I guess you are missing the point that smallx264 is a totally different tool from official GUI or VidCoder. AFAIK offical GUI and VidCoder are developed using WPF while Delphi is used for Smallx264. It most likely won't run on win98 or ME because of unicode stuff but it should run on XP.
Edit: To make things even more clear, Smallx264 calls HandBrakeCLI to do the job. -
What sort of error do you get? Is it related to the GUI or HandBrakeCLI?
Update 1.1
Change log:
-1.1.0
-Added: "Add Folder Tree" option
-Added: Folder of the source will be created in the output
-Reverted: HandBrakeCLI to a previous build
https://sourceforge.net/projects/smallx264/ -
@mike20021969 an other user too reported that and said version 0.9.1 worked for them so I included HandBrakeCli from that build in 1.1.
GUI Tool created for batch video tasks
By VirtualDoobMon in forum ProgrammingReplies: 10Last Post: 10th Jun 2019, 08:50 -
Batch processing GUI for HCEnc
By freebird73717 in forum ProgrammingReplies: 15Last Post: 20th Apr 2011, 21:31 -
Simple batch encode H.264
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2009, 12:32 -
Seeking A Better Hammer -- Simple GUI to Convert Ripped DVDs
By GrayStrickland in forum Video ConversionReplies: 10Last Post: 15th Feb 2009, 03:08 -
DeVeDe - easy, batch capable video to DVD Linux/UN*X GUI
By danboid in forum LinuxReplies: 1Last Post: 23rd Oct 2008, 18:48
