I wish to edit an anime video in Sony Vegas so I converted it from .mkv to .mp4 using Bigasoft MKV Converter, the audio and video turned out fine but for some reason the program did not pick up on the subtitles and I cant seem to find an option to change that.
To fix this I used MKVExtract to extract the subtitles and then add them afterward (there is an option in Bigasoft to import from a subtitles file) yet when I add them it doesn't keep the same formatting as the subtitles originally had. It defaults to a different font, doesn't pick up on color changes and worst of all if a line of text is too long it just cuts it off instead of adding a second line underneath.
So basically what I'm asking, is there a good video converter that will convert from .mkv to .mp4 (or any other file type that Sony Vegas accepts) whilst keeping the subtitles correctly formatted? Alternatively, is there a way I can add subtitles to an .mp4 file and keep the formatting?
Thanks for your time.
MKV to MP4 with subtitle
By Anon13 in forum SubtitleReplies: 14Last Post: 28th Sep 2012, 21:41 -
Cannot seem to convert MKV to MP4 or AVI to MP4 without audio sync issues
By Matth3w in forum Video ConversionReplies: 0Last Post: 16th Sep 2012, 14:36 -
MKV subtitle issues with Samsun LED TV
By spacetoilet in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2011, 04:15 -
mkv to mp4(ps3) subtitle issues
By HeroSmero in forum Video ConversionReplies: 2Last Post: 3rd Jan 2010, 20:43 -
Issues Converting MKV to MP4 (could be due to damaged MKV header??)
By MohQ in forum Video ConversionReplies: 1Last Post: 1st Feb 2008, 04:10
