I have an h.264/avc video in mp4 container.
I want to add subtitles in the dvb format using ffmpeg. If this possible?
I am trying
But then I get the fatal errorCode:ffmpeg -i input.mp4 -i subtitle.sub -c:v copy -c:a copy -c:s dvbsub output.mp4
Can I even use ffmpeg or will I have to something else?Code:Stream mapping: Stream #0:0 -> #0:0 (h264 -> libx264) Stream #0:1 -> #0:1 (aac -> libvo_aacenc) Stream #1:0 -> #0:2 (subrip -> dvbsub) Could not write header for output file #0 (incorrect codec parameters ?): Operation not permitted
Can anyone tell me if mp4 supports dvb subtitles?
Does anyone have a sample file containing dvb subtitles? any format and any container? -
iirc it supports:Can anyone tell me if mp4 supports dvb subtitles
a. CC
b. ttxt subtitles
c. idx/sub subtitles
you might want to read: http://www.iphonelife.com/blog/87/how-you-can-convert-your-dvb-recordings-subtitles-id...-mp4-subtitles
Adding subtitles to a video TS file
By chiburu in forum SubtitleReplies: 2Last Post: 17th Jul 2011, 15:32 -
Adding subtitles to a video - any programs out there?
By Bansaw in forum SubtitleReplies: 2Last Post: 23rd May 2011, 17:34 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 16:53 -
Adding time values into video or as subtitles
By Heliooos in forum EditingReplies: 1Last Post: 23rd Apr 2010, 04:54 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10
