Hi, I'd like to encode some long movies into dual layer dvds to get a better bitrate, but the dropdown menu only has 1 dvd option. Is there any way I encode for dual layer dvds?
Can't you set a custom video bitrate? Then can you calculate the video bitrate with a bitrate calculator.
To set up for a dual layer DVD, set the options for DVD encoding as usual,
then enter the bitrate calculator in the Video tab.
Set the number of discs to "2" of “DVD 4GB”. This will change the size for calculations to 8000 MB.
Next, click the Rate button to change the video bitrate to match the size number.
The new video bitrate will be calculated using all information, such as file size, duration (minutes), and audio bitrate.
As long as "Split" is unchecked in the Options tab, the output will be for one dual layer disc.
Unfortunately, when trying the above method ffmpegx just encoded for a single dvd -- not sure what went wrong.
Okay, I was able to encode by using the general MPEG2 setting and NOT having it set to author a dvd in TOOLS. After the M2V and AC3 files were created I was able to mux/author in Tools as separate steps. When I had the author dvd box checked earlier it created a single layer dvd despite the fact that I had 2 dvds of 4gb selected in the video tab.
Convert a single-layer disc to dual layer?
By JasonQuinn1992 in forum Authoring (DVD)Replies: 5Last Post: 10th Nov 2012, 01:24 -
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
encoding dual layer dvd
By francoislebel in forum ffmpegX general discussionReplies: 1Last Post: 29th Aug 2009, 06:14 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00
