  1. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    After some months, Amaman release the awesome tool: AmarecTV, 2.31 version.
    This versions has some new features (Replay mode, Live Engine HD, Frame Rate Select).
    Live Engine only in japanese installer, but work in english mode.
    Link: AMARECTV-2.31
    Mirror:
    AMARECTV-2.31
    Claudio
    Feb 2008
    Poland
    Does AmarecTV has "disable screensaver" option at last?
  3. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Nope.
    Claudio
  4. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    I created an installer for new AmarecTV, including live setup and multilanguage install.
    The file was scanned by ESET and BIT DEFENDER and contains md5 file check.
    Link: AMARECTV 2.31
    Name: AmarecTV Setup.exe
    CRC-32: aede0b5d
    MD4: 23f18b26e0a0aad45cf66e07c3f8117c
    MD5: a57d70ce0292c5d5093745a8ec2c7d55
    SHA-1: 3e1dd1d0a8ae38589ff3fa45b0e24fcc1751a212
ID:	15834Click image for larger version
    Claudio
  5. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    Can you please explain the advantages of the new features?
  6. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Replay mode:
    You can watch, record and replay video at same time in realtime. Its use RAM avaliable from your PC, no HDD, more RAM more replay time.
    Live engine:
    Before its limited to stream 320x240x30fps. Now you can make it in 1080p@60, its perfect to Xsplit ou FFsplit.
    In old version (1.15) some programs not work using amarec video device. Now stream, watch and record are full work.
    Four virtual devices, looks like DXTORY. Its make my gamer life easy
    Select Frames:
    Some codecs not work using old amarecTV in 50/60fps. Now its full complete. All codecs tested work in any device.
    Claudio
