I have .h264 and .aac elementary streams. They also have closed caption data in EIA 608 and 708 format. I used mp4box join the streams using the following command
This did the job but somehow the CC data was removed. Does anyone have any idea why? the original video was in 29.97 fps so nothing has changed.Code:mp4box -add nicu_cc.h264:fps=29.97 -add nicu.aac -new nicu_withcc.mp4 AVC-H264 import - frame size 720 x 480 at 29.970 FPS AVC Import results: 23020 samples - Slices: 600 I 9018 P 13402 B - 23021 SEI - 599 IDR Stream uses forward prediction - stream CTS offset: 2 frames AAC import - sample rate 44100 - MPEG-4 audio - 2 channels Saving nicu_withcc.mp4: 0.500 secs Interleaving
The media info of the original video elementary stream is
General
Complete name : C:\nicu_cc.h264
Format : AVC
File size : 139 MiB
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 128 r2216 198a7ea
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=40 / keyint_min=4 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Text #1
Format : EIA-608
Muxing mode : SCTE 128 / DTVCC Transport
Bit rate mode : Constant
Stream size : 0.00 Byte (0%)
Text #2
Format : EIA-708
Results 1 to 22 of 22
I don't think mp4 supports such closed captions. You could try convert the cc to srt subs or ttxt subs instead.
It does. I have done this before.
MP4 file with CCLast edited by wotdefcuk; 17th Jan 2013 at 15:41.
sorry, don't know either.
What tool did you use to embed the CC data into a x264 video stream? -
yes that worked but i am still in testing mode therefore that was my first file and there were a few errors in it so i abandoned it and started from a new file. Now mp4box started stripping the cc. I even make sure that the CC track is in the h.264 elementary stream before I try muxing it using MP4box
General
Format : AVC
File size : 139 MiB
Video
Format : AVC
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Text
Format : EIA-608
Stream size : 0.00 Byte (0%) -
What was different between the 1st successful attempt and the 2nd unsuccessful one ? (how did you get the 1st one to "Work") ?
What software or hardware is capable of parsing CC in MP4 ? Are you able to see them ? -
The hardware used is a STB (enseo.com) and I am streaming to it using VLC. I havent found a player that can decode the CC in and play it. But as the CC data is in the video stream it self therefore the STB gets it and is able to play the file and toggle CC as need be.
Having said that VLC should be able to play this. http://mikecheat.com/disjrhd.ts
I am not sure why this happens because both of the captions look the same. -
My fault. The captions are still there its just that I can't see them in media info. That is really weird behavior and I dont know why it is happening.
This is what I see but the captions can be played through the stream.
General
Complete name : C:\nicu_withcc.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 156 MiB
Duration : 12mn 48s
Overall bit rate : 1 709 Kbps
Encoded date : UTC 2013-01-17 21:35:06
Tagged date : UTC 2013-01-17 21:35:06
Video
Format : AVC
Codec ID : avc1
Duration : 12mn 48s
Bit rate : 1 513 Kbps
Maximum bit rate : 5 019 Kbps
Width : 720 pixels
Height : 480 pixels
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.146
Stream size : 139 MiB (89%)
Title : nicu_cc.h264:fps=29.97 - Imported with GPAC 0.5.0-rev4065
Tagged date : UTC 2013-01-17 21:35:10
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 12mn 48s
Bit rate mode : Variable
Bit rate : 192 Kbps
Maximum bit rate : 202 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 17.6 MiB (11%)
Title : nicu.aac - Imported with GPAC 0.5.0-rev4065
Encoded date : UTC 2013-01-17 21:35:09
Tagged date : UTC 2013-01-17 21:35:10 -
Try
Code:ffmpeg -i video.h264 -i audio.aac -acodec copy -vcodec copy video.mp4
yup tried that and the meta data about the captions is getting removed here too. Is there a way to maintain the metadata? It's in the format below
Text #1
Format : EIA-608
Text #2
Format : EIA-708
Because I am trying to do this all programmatically. So I can QC the file after everything is said and done.
But extracting the elementary streams , then wrapping with mp4box works in that sample
How is that elementary stream different than the other elementary stream that doesn't work ? (Other than resolution, etc)
Maybe you can provide more information on what you did exactly. Maybe you are using a certain mp4box build that overwrites metadata
x264 GUI specifically for blu-ray compliant elementary streams
By turk690 in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Apr 2012, 20:20 -
Can't Mux audio & video streams to MP4 without a problem
By spycam in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2010, 17:49 -
3 movies, 6 elementary streams, 1 DVD
By Pholder in forum Authoring (DVD)Replies: 1Last Post: 5th Aug 2010, 09:51 -
Multiplexer for elementary streams for a BD-R / AVCHD
By BobaFett77 in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Jun 2010, 17:59 -
demux a .mp4 to elementary streams
By halsboss in forum Video ConversionReplies: 4Last Post: 28th Nov 2009, 17:38
