This is my first post here and I'm also relatively new to authoriing my own videos.
I'm trying to use my PC webcam (Gigaware HD/Radio Shack) to record short video segments to be aired on cable TV. The producer wants the files in HD format & suggested I use Moviemaker to record them.
I've made a few of my own videos using this webcam & other recording software and it doesn't seem to sync very well (audio & video aren't aligned) Using Moviemaker & listening to the file in Moviemaker there's definitely a sync problem.
Is this due to the quality of my equipment or any other obvious issue I should address? Is it a software issue?
Here's the Dropbox link: https://dl-web.dropbox.com/get/hagel%20social%20tv%20hd.mp4?w=a32f8e5f
The producer surely gave you an absolutely UN-professional advice. Drop Windows Movie Maker, to begin with. First, capture to a fast video codec and to UN-compressed audio in a constant-frame-rate container (read: AVI). Later, edit and re-compress both the audio and the video.
Can you recommend recording/editing software that would not be terribly complicated for someone relatively new at this.
Demux audio from ntsc video and mux with pal,audio sync problems
By luis67 in forum AudioReplies: 6Last Post: 17th Nov 2012, 05:43 -
Audio Sync Problems
By nephesh in forum Video Streaming DownloadingReplies: 0Last Post: 12th May 2011, 09:10 -
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 10:49 -
Audio Sync Problems
By mattr in forum MacReplies: 4Last Post: 7th Jul 2008, 10:55 -
Audio Sync Problems
By Blue_3 in forum AudioReplies: 5Last Post: 10th Apr 2008, 19:17
