I have heard that the PA has better picture quality. Why is that if they cost the same? Also, would someone tell me what progressive scan is and what it does?
The P uses a mpeg decoder chip with BT designation.
The PA uses a mpeg decoder chip with the CS designation. the CS is supposely a better decoder. I personally cant tell the difference.
Progressive scan, using the search function on this forum or google should have provided you with the answer easily.
http://electronics.cnet.com/electronics/0-3219398-8-6226096-1.html?txt
