Are you using bd rebuilder or just tsmuxer?
Have you ripped the blu-ray first with dvdfab? -
This may not be your problem but make sure that all your hdd are formatted NTFS. When I started processing HD video I forgot that one of my drives was fat32 and a temp folder used by one of the sub programs was on that drive so it cut off at the 4gb limit. There was no helpful message.
There's not much to do but then I can't do much anyway. -
My mistake this is happening when trying to use bd-rebuilder with AnyDown in the background, also Anydown wiil not recognixe any drive I try to install it on the HD or rip. Thanks
James Durkin -
Isn't this same issue as your other thread? https://forum.videohelp.com/threads/352501-Cannot-copy-Homeland?p=2213303#post2213303
Ts Muxer Blues
By romanticwarrior in forum Authoring (Blu-ray)Replies: 3Last Post: 2nd Dec 2010, 09:17 -
RMVB Subtitle Muxer
By El Heggunte in forum SubtitleReplies: 0Last Post: 11th Jul 2010, 21:49 -
H.264 encoder with TS muxer
By kary.sharma in forum Video ConversionReplies: 1Last Post: 30th Dec 2008, 03:35 -
Resolution with ts muxer ??
By bobotheclown in forum Authoring (Blu-ray)Replies: 6Last Post: 27th Nov 2008, 18:42 -
menc muxer problem ?
By Ahmed28 in forum Newbie / General discussionsReplies: 0Last Post: 10th Nov 2008, 07:27
