hi, when converting the first half of all my avi files into mpg with tmpgenc, at the end i get 'error encoding audio' and a file that is unplayable! does anybody know why this is happening and how it can be corrected? i'm using kwag's pal template, i've tried it with others aswell. this is the info of the avi. file i'm encoding with!
Length 50m 55s
38188 frames 352W x 288H, 24 bits per pixel
12.50 frames/sec
Video compression: mp43
Stereo audio, 24000 x 0-bit samples/sec
Audio data rate = 7000 bytes/sec
Average size per frame = 3669 bytes
thanx for any help!!!!
I think we all get a 99% error
but the output should be just fine. If your output is no good then there is something wrong with the AVI.
Just encode a few minuets, is it ok ? If not check the AVI for bad frames.
The error usually happens when the video length and audio length at the end are different.
megui audio encoding error
By IPHONEHQ in forum AudioReplies: 0Last Post: 25th Dec 2011, 09:46 -
Audio encoding error with MeGui
By [ss]vegeta in forum AudioReplies: 3Last Post: 23rd Oct 2011, 14:51 -
RMVB conversion end up without audio
By alc112 in forum Video ConversionReplies: 22Last Post: 14th Jan 2010, 00:34 -
Error While Encoding Audio On VirtualDub
By ashwin.terminator in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2009, 09:00 -
BD-Rebuilder has Error in encoding audio
By teedster in forum Blu-ray RippingReplies: 2Last Post: 14th Oct 2009, 09:07
