The question in the thread title
Which are the free alternative programs that have a function equivalent to VideoReDo's "QuickStream Fix"?
Thank you very much
				Results 1 to 11 of 11
	Falco2000, video newbie.
 Let's everyone help each other.
	For mpeg2 streams, sometimes projectx or pvastrumento can help fix errors similar to videoredo's quickstream fix
	Thankyou pdr, I tried them all, but unfortunately they didn't help me in the solution of this problem:
 https://forum.videohelp.com/threads/351197-Progressive-loss-of-audiosync-during-convers...G-2-to-MP4-whyFalco2000, video newbie.
	Free software that can fix all the same sorts of stream errors as VideoReDo handles doesn't exist, and may never exist. Download VideoReDo's trial to see if it can fix your problem file. If you have a continuing need to work with files that have errors in the stream or missing frames, it is worth the purchase price.
	That is nice to know and makes it almost worth the price of admission alone. I will test it out now on a trial. ProjectX does a great job and I have been using it successfully for quite some time but I can not figure out how to get it to preserve the CCs, even though it claims it handles them, as there simply is no good documentation.
	Not from my experiences. I tried the latest version a while back and it didn't repair anything it claimed it could. I kept having issues with files it processed so I went back to ProjectX which actually works and is free....albeit is it a little old and no longer under development.
	MPEG GOP user data, including N. American closed captions, are often stripped by software when video streams are processed unless the software is designed to copy it instead.
 ProjectX was developed to process DVB transport streams. There wasn't a compelling reason to add the ability to copy N. American closed captions stored in the GOP user data because none would be present in DVB transport streams.Last edited by usually_quiet; 20th Mar 2022 at 09:33. Reason: typo Ignore list: hello_hello, tried, TechLord, Snoopy329
  Help. Avisynth Error Message "no function named limitedsharpen"By Pitorasilo in forum Video ConversionReplies: 7Last Post: 27th Dec 2010, 07:13
  Cyberlink Power Director 7 - "Create" Function Problems!By lapetite_66 in forum Newbie / General discussionsReplies: 4Last Post: 29th Jul 2009, 21:01
  Help. Avisynth Error Message "no function named deblock"By hypnoticpimp in forum Video ConversionReplies: 13Last Post: 28th Sep 2008, 00:45
  Set/Fix QuickTime "atoms"/"flags"?By rumplestiltskin in forum Newbie / General discussionsReplies: 3Last Post: 22nd Sep 2008, 14:07
  Seeking avisynth function for "blend-a-field" ideaBy vhelp in forum EditingReplies: 2Last Post: 21st Sep 2008, 21:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
