1.) I have an MP3-CD player. Would it be better to fast forward 30 minutes into an MP3 or should I dub my books on tape, onto tape and use a tape player.
I'm traveling and I want to know the best way, to reduce space and weight.
Also can tapes be earsed by those new high power x-ray machines they r using.? Will my cd-player be safe?
2.) Were can i find the Simillarion by J.R.R. Tolkien, it was a BBC radio play n i've seen parts on winmx but never all of it
Why would you have to fast forward through the MP3? Why not just break it up into pieces? For example, cut them into 10 minute tracks so you can just jump through the "sections".
Your MP3 player and all CDs will be fine in XRay machines. As long as you don't have a boxcutter hidden in it.
As for the Similarian, go to a used book store and buy the tapes, and capture them to MP3. -
that's a very very good idea. Thanks
i can see organization being a problem with like 15 audio books on one disk -
You can download audio books from www.audible.com. They have proprietary player software, but also have a burn to CD option that creates standard audio CDs. I wanted the audio in MP3 format, so I played it on my PC and captured it to a .wav file using TotalRecorder. From there I converted to MP3 and burned it to a CD.
They have The Silmarillion in their catalog, but it's in 3 parts at $15.95 each. -
1.) Can anyone suggest a freeware mp3 cutter.
2.) Neywhere I can get Silmirillion Free>
3.) How do i overcome this problem:
1, 10, 11, 12, 2, 3, 4, 5, 6, 7, 8, 9
why won't it go 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 -
What do you mean by "MP3 cutter"? If you're looking for MP3 ripping software or CD burning software, you can download the basic version of MusicMatch Jukebox from www.musicmatch.com. The basic version is free and supports both ripping and burning.
I have Lord of the Rings MP3's but they are 55 minutes long.
It would be so battery consuming to fast forward 45 minutes into one.
I'd like to cut the mp3 into 5 10 minute MP3's.
remember that I have only a finite supply of batterys and for a week I won't be able to really purchase new ones.
I will also be running a digi-cam, further hurting my supply.
I do plan to buy the latest and finest in rechargeable batteries though.
Books on subtitling - Practice and Theory
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 11th Mar 2012, 13:33 -
Phone books?
By stiltman in forum Off topicReplies: 16Last Post: 18th Sep 2011, 17:01 -
What type of books do you read?
By johns0 in forum PollsReplies: 11Last Post: 18th Apr 2011, 14:18 -
How to burn tv series/burning audio books
By jenny56 in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 18:42 -
How often do you read books for your personal enjoyment?
By yoda313 in forum PollsReplies: 27Last Post: 24th Sep 2007, 11:08
