is there a program which can remove subtitles from a movie which have been embedded into the .avi
You mean they're hardcoded? As in no separate subtitle file? I've never seen a video where I hated the subs enough to try something so silly as remove hardcoded subs.
Try doing a web search on, say, "video how to remove hardcoded subtitles". You'll see why.
Basically, if they're hard coded, you'd have to reencode the video, and you won't get perfect results by any means irrespective of the loss you'll get with reencodiing.
There is nothing underneath hard coded subtitles. It's not a layer superimposed on the video. If you've ever seen watermark removal, it's the same thing. Possible but I can't help you. I'd never do it. -
ok fully understand it was not a major problem anyway but thanks for replying I understand more now
remove subtitles from half SBS movie
By sportflyer in forum SubtitleReplies: 2Last Post: 1st Jan 2012, 22:27 -
How Can I Remove the Subtitles from a .VOB File and a .AVI File?
By channelz28 in forum Newbie / General discussionsReplies: 3Last Post: 21st Nov 2011, 19:45 -
Remove SubTitles
By fredb38 in forum SubtitleReplies: 1Last Post: 14th Aug 2009, 17:55 -
Remove subtitles from .avi
By Comrie19 in forum Video ConversionReplies: 4Last Post: 11th Jul 2009, 18:38 -
Subtitles in AVI movie
By andreltr in forum Newbie / General discussionsReplies: 2Last Post: 19th May 2009, 23:41
