Hi, I tried to log on and got redirected every time
So i tried logging in as admin and it worked okay so apologies.
My problem is this I have a the following setup and cannot capture digital video without dropping 30-50% of frames
1ghz CPU intel
80gb hard drive 7200 rpm
512 mb ram
firewire card Texus Instruments?
Sony DCR TRV120E Digital VCR
With either Premiere or MGI Videowave
Ive tried closing down everything else running in the background except for a couple of things.
Please help
do you have a seperate partion for the captures? I have a seperate drive(s) for my firewire and I drop 1 to 2 frames for every 68000 frames or so of capture, using a SIIG firewire board ( texas instruments chipset ), 512 mb ram and a intel 933 p3 proc ( 815 solano chipset ). So it's similiar to yours. My capture drives are ata 100 7200 rpm 150 gb ( 2 - 76gb drives in raid0 fashion ) on a hipoint controller. Captures are made thru Adobe Premeire and Ulead Media Studio v 5.0.
I would agree with tommy, sounds like you dont have DMA enabled for your hard drive
Craig -
Hi,
Do you have the indexing service disabled. Right click on c: or any other drives if using 2000 or XP and go to properties and disable indexing.
Also disable i.e. uninstall any virus killer software or Norton optimising utils you might have installed. Virus killers tend to cause a very high performance hit on capture machine.
Is you capture machine a lean set-up with plenty of empty space on your capture drive and defragmented. Or is it used for other purposes and therefore as other things installed which might hamper it.
Also might help a useful link from computervideo magazine website http://198.78.168.254/new.html
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 12:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
System dropping frames because it's getting old?
By quanz in forum Capturing and VCRReplies: 16Last Post: 30th Nov 2009, 07:20 -
WinDV dropping frames
By 2Bdecided in forum Capturing and VCRReplies: 3Last Post: 17th Oct 2009, 04:23 -
Dropping frames while converting to .dv
By Huntr777 in forum MacReplies: 1Last Post: 10th Jun 2009, 17:19
