Ok so I just got Pioneer AVH-P4300 DVD for my truck that can play divx and avi format.
I already downloaded bunch of videos via wondershare ultimate converter (good quality) and I choose output format AVI.
I want to burn a DVD disc with bunch of AVI videos on it. Avarage size of each AVI file is around 600-800 mb so I would put as much as I can on the 1 disc.
My question is what software can I use to do that and will it keep the same quality while playing on Pioneer head unit?
Thank you in advance
Didn't you use wondershare converter to convert to avi divx/xvid? But they wont play or what?
And this is video conversion because you are not authoring a standard dvd-video. Moving you. -
No No I didnt burn the disc yet. I was wondering what software should I use to burn the avi files on DVD and how to do that ?
Sorry you missunderstood me my english isnt that great
What would be the best way and what software would be good to keep same video quaility after burning them on the disc?
Thanks -
I would try a few of those avi files on a usb flash drive/cdrw/dvdrw first. Just to see if the avis play at all.
I need to burn avi videos onto a dvd to play on my standalone player
By -mm- in forum Video ConversionReplies: 10Last Post: 23rd Jun 2012, 15:32 -
Which DVD should I use to burn avi files to play on standalone?
By Stealth3si in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2009, 10:22 -
Play back Music Videos In My Car
By trevz87 in forum Portable VideoReplies: 6Last Post: 22nd Mar 2009, 18:58 -
MP4 doesn't want to play on car DVD Player
By Metallo in forum Portable VideoReplies: 6Last Post: 4th Jan 2009, 20:44 -
burning music to cd so it will play in car or standalone cd player
By deadman1972 in forum AudioReplies: 4Last Post: 8th Aug 2008, 05:43
