its a PAL source. originally ntsc at 23.976 framerate.
Results 1 to 12 of 12
It was converted from 23.976 fps (maybe 24) to 25 fps by duplicating one frame out of every 24. Then it was captured with the wrong field order so the fields are out of phase.
TFM()
TDecimate(mode=2, rate=23.976) -
Doesn't look interlaced to me (MediaInfo and others say it's PAL 25fps progressive). But on SeparateFields with TFF, motion is back and forth. I see cycles of 2 fields duplicated, as with telecine (or maybe it's just really late here).
So, how would one get back to normal, and what would TFM/Decimate do with the wrong field order?Last edited by sanlyn; 25th Mar 2014 at 03:12.
Yes, although I'd do it slightly differently:
TFM()
TDecimate(Mode=1,Cycle=25,CycleR=1)
Yes, encoding it as progressive was a major screwup. But it's heavily interlaced. Look at it with something that doesn't deinterlace it, like an AviSynth script with no filtering applied and then opened in VDub. As jagabo said, it was converted by adding a duplicate frame a second, in the form of adding a duplicate field every half-second. So in every second there's half a second of continuous interlacing when there's steady movement. Follow the moon beginning at about the 13th second. -
Right, the moon motion is what I was watching, then later with figures moving. Those frames told me that this was interlaced + added fields + field order error + encoded as progressive. Very creative.
Frames are encoded progressive but with 2:2:2:2:2:2:2:2:2:2:2:3 pulldown flags. So they come out of the encoder interlaced.
TFM() works for both TFF and BFF, as long as the field order is flagged correctly.
This might be a case where Ignore Pulldown Flags in DgIndex will work. Then just
But if parts of the video are different that may fail.Code:Mpeg2Source("sample.d2v") AssumeFPS(24) # or 23.976
<edit>
Yes, different parts of the video are encoded differently. I just tried Ignore Pulldown Flags and it results in A/V sync errors. Also, if you use Mpg2Cut2 to mark and save small sections you'll see different encodings. Use the scripts I or manono posted.
</edit>Last edited by jagabo; 12th Jan 2013 at 08:28.
i just wanted to know what you guys think of my final encode. Im not sure if I resized it correctly.
Which means I was wrong. I should have known when I saw it being 83% video in DGindex that there was pulldown involved. It just didn't click when I saw that. I apologize to you, sanlyn, as it really is progressive (with pulldown) and encoding it as progressive wasn't a mistake at all. I have never seen a retail DVD encoded this way. It shows other signs of having been 'home-made' too. mmbwdpnz, is this really a retail DVD or did you download it from somewhere?
I bought it off amazon. It's from Italy and yes its from a retail dvd. Its better quality then the Japanese dvds it just has a few motion problems with the framerate.
If you had just run the scripts you'd be done by now and could compare the results.
Do all DVD players deinterlace DVDs made from mini-dv camcorders?
By granturissimus in forum Newbie / General discussionsReplies: 12Last Post: 16th Jan 2011, 21:01 -
Dealing with Anime DVDs
By tehslax in forum Newbie / General discussionsReplies: 4Last Post: 28th Nov 2010, 16:06 -
Framerate consern after deinterlace
By greyfalcon in forum Newbie / General discussionsReplies: 18Last Post: 27th Feb 2010, 21:50 -
Converting Anime DVDs to AVI (AutoGK)
By vangelon in forum DVD RippingReplies: 6Last Post: 18th Nov 2009, 04:25 -
Anime Encoding From DVDs to h264.
By kwanbis in forum Newbie / General discussionsReplies: 9Last Post: 11th Mar 2009, 20:31
