    Sep 2012
    egypt
    i have this link
    rtmp://www.teledunet.com:1935/teledunet<playpath>2m <swfUrl>http://www.teledunet.com/tv/player.swf?repeat=always&autostart=true&stretching_=none&id0=2692800495060&streamer=rtmp%3A//www.teledunet.com%3A1935/teledunet&file=2m&provider=rtmp&skin=bekle/bekle.xml <pageUrl>http://www.teledunet.com/tv/?stretching=none&file=rtmp://www.teledunet.com:1935/teledunet/2m
    when i use it in script batch to play over VLC it works perfect
    like this
    rtmpdump -v -r rtmp://www.teledunet.com:1935/ -W http://www.teledunet.com/tv/player.swf?id0=teledunet^& -a teledunet -p http://www.teledunet.com/tv/ -y 2m -o- |  %vlc% -
    but when i try to mak it play over Flash media player it never play and gives me connection failed
    this is my batch command so can any one tell me what my mistakes or what should to do to make it works over flash media
    @echo off
    :TOP
    title live ch
    set "id0=teledunet"
    set "streamer=rtmp://www.teledunet.com:1935/teledunet"
    set "swf=http://www.teledunet.com/tv/player.swf"
    :MENU
    echo.
    echo    (1) = 25 Channel
    echo    (2) = 2M
    echo.
    goto CHOICE
    :CHOICE
    set /p "choice=Enter #:"
    if /I "%Choice%"=="E" goto EXIT
    if "%choice%"=="1" set "file=25_channel" & goto PLAYER
    if "%choice%"=="2" set "file=2m" & goto PLAYER
    :PLAYER
    cls
    echo. Stream is starting.... Close Flash Player to return to Menu.
    flashplayer_11_sa.exe "%swf%?repeat=always&autostart=true&stretching=exactfit&id0=%id0%&streamer=%streamer%&file=%file%&provider=rtmp&skin=bekle/bekle.xml&icons=true"
    goto MENU
    exit
    please please any one help me
    Oct 2005
    666th portal
    unless you are executing the batch file in the folder with flashplayer you may need to give it's full path. like c:\program files\common\..........
    Sep 2012
    egypt
    i am not prof to treat with Batch , so can you explain in other way ,make it simple
    Oct 2005
    666th portal
    sorry none of your links work. can't even open - www.teledunet.com
    Sep 2012
    egypt
    my mate friend , the site works well
    and this picture of the channels
    so please help me
    Oct 2005
    666th portal
    you need to fix your batch file and find the exact url to pass to flashplayer. it can't open the mixed up stuff you're sending it.
