Hello guys!
http://ffmpeg.org/trac/ffmpeg/ticket/1679
FFMPEG: "Ability to identify progressive segmented frame material in h.264"
What does it mean?
Results 1 to 11 of 11
I mentioned this in your other thread, it's already been implemented. Frame rate is read correctly, instead of the field rate
Recent ffmpeg (2013) 25fps
Input #0, mpegts, from 'mozdony.mts':
Duration: 00:00:24.58, start: 0.004033, bitrate: 24881 kb/s
Program 1
Metadata:
service_name : Service01
service_provider: FFmpeg
Stream #0:0[0x100]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 19
20x1080 [SAR 1:1 DAR 16:9], 25 fps, 50 tbr, 90k tbn, 50 tbc
Stream #0:1[0x101]: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo,
fltp, 256 kb/s
Duration: 00:00:24.58, start: 0.004067, bitrate: 24881 kb/s
Program 1
Metadata:
Stream #0.0[0x100]: Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9
], 50 fps, 50 tbr, 90k tbn, 50 tbc
Stream #0.1[0x101]: Audio: [129][0][0][0] / 0x0081, 48000 Hz, stereo, 256 kb
/s -
Are there any FFMPEG codes to achieve that?
Okay, but the Mp4 container problem is still remained in direct-stream-copy mode! The avi container can produce 25fps, but the play-speed of the avi video is half of the normal speed.
OR: could you solve that mp4 and avi problem? Test file: http://dictaphone.atw.hu/mozdony.MTS (Only 67Mbyte)Last edited by Stears555; 11th Jan 2013 at 10:54.
"ability to identify" only deals with correctly identifying PsF. There are still other issues with ffmpeg's MP4 muxer (i already mentioned this in your other thread)
Ability to identify correcty is only the 1st step. For example, if youtube eventually merges this and implements it correctly, it should no longer deinterlace your progressive videos
Don't expect everything to be fixed so quickly - these developers are volunteers and work for free... Many things on the "to do" list are higher in priority and still haven't been dealt with for years.
Do you remember this conversation?
https://forum.videohelp.com/threads/343067-I-want-to-transform-my-PSF-MTS-camcorder-vid...=1#post2137478
Original file just has the field_pic_flag set to 1. This means it's interlaced encoding, not progressive encoding - this is the root of all your problems
e.g
Code:ffmpeg -i input.ext
Again, it doesn't work for MP4 properly , use something else like MKV
Code:ffmpeg -i input.ext -vcodec copy -acodec copy output.ext
e.g
ffmpeg -i mozdony.mts -vcodec copy -acodec copy output.mkv
Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Format settings, GOP : M=3, N=12 Codec ID : V_MPEG4/ISO/AVC Bit rate mode : Variable Bit rate : 22.3 Mbps Maximum bit rate : 22.7 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Original frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Default : Yes Forced : No Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 24s 620ms Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : 464ms Stream size : 769 KiB (1%) Default : Yes Forced : No
it takes them normally a while but they fix bugs (last thing I reported directly myself https://ffmpeg.org/trac/ffmpeg/ticket/978 got fixed after half a year
, but that's okay, I knew how to workaround the problem and I also knew that not so many people would run into the problem that really bugged me
FFMPEG has frame-rate problem with progressive segmented frame in avi container too...
Can you send a ticket for a Youtube employee too, about the Progressive segmented frame problems?
Further info and sample videos about the youtube problems:
http://productforums.google.com/forum/#!msg/youtube/TCtyuf2PYWk/nvs9Hr2SYcMJ
Weave deinterlace plugin for Progressive Segmented-Frame videos(After Effec
By Stears555 in forum Video ConversionReplies: 1Last Post: 8th Feb 2012, 15:20 -
how we can implement "VirtualDub" or "FFmpeg" with my C# windows applicati
By dhemittal in forum ProgrammingReplies: 0Last Post: 8th Jun 2010, 07:17 -
[FFMPEG] Known problem with "Frame size must be a multiple of 2"
By yamyam in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2009, 12:52 -
Progressive download/"fast start"
By ChetWesley in forum ffmpegX general discussionReplies: 3Last Post: 14th Oct 2008, 12:56 -
Please explain "Progressive Scan DVD menus"
By schematic2 in forum Authoring (DVD)Replies: 1Last Post: 2nd Oct 2008, 19:25
