    Jan 2013
    são paulo
    hello,
    i'm searching for help, can't find an answer over the internet. so i'm here.
    my green FX button of audio edition in vegas (8) is locked, suddenly i can't see the window with the FX options opening.
    i'm editing this video and have a such a close deadline.
    the same kind of bottom for video editing working like always worked, poping up the window of fx at me normally.
    best
    a.
    Oct 2005
    666th portal
    Close the program. Now press CTRL+SHIFT while double-clicking on the program's icon to launch it. Continue to hold the CTRL & SHIFT keys until the program is fully up and loaded.
    In newer programs, you will see a window that asks "Do you want to reset all preferences to default values?" Place a checkmark next to "Delete all cached application data" and then click Yes.
    if that doesn't work you'll have to un-install and then re-install vegas.
    Jan 2013
    são paulo
    it works.
    thank you!
