please help me i use dvd fab to copy bluray to my hard disc but it convert the sound to ac3!!!i want the original sound of bluray what to use ???
Results 1 to 9 of 9
Are you also compressing or converting the blu ray as you rip to the hard drive?
Try ripping with the free section of DVDFab, called DVDFab HD Decrypter. This will leave everything intact, and you can choose to rip the entire movie or just the main movie.
Or you can use MakeMKV to rip blu ray. It will put the main movie in an mkv file, uncompressed. Or you can use the Backup option, which will rip all of the movie in file format. -
stop using dvdfab and start using dvdfabhddecrypter!
Scott -
Players:
MPC-HC [and lav filters to stream original sound to your receiver] or
Gom player or
TMT 3.
Have a nice day,
N
LPCM, Dolby TrueHD, DTS Master Audio and FLAC
By Mr_X2012 in forum AudioReplies: 12Last Post: 7th Sep 2012, 09:02 -
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 16:57 -
DTS-HD Master Audio Extraction from Tsmuxer
By m1ke486837 in forum Blu-ray RippingReplies: 0Last Post: 5th Jan 2011, 20:29 -
DTS Master Undetermined with BluRIP
By nikemouse in forum AudioReplies: 1Last Post: 11th Nov 2010, 17:34 -
can you rip blurays and then remove audio commentaries without reencoding?
By krohm in forum Blu-ray RippingReplies: 2Last Post: 1st Mar 2010, 09:54
