  1. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi All,
    The last time I use this software was in 2006.
    It was straight forward. Now, it has many features. I am stuck at export slideshow.
    HcEnc reported script error. I just did a fresh install. I couldn't preview either. It said Direct X End-User runtime is not updated.
    Any tips to fix this problem is much appreciated.
    Thanks in advance.
  2. Member pchan's Avatar
    Mar 2003
    Singapore
    OK. The problem goes away when I update the Direct X Runtime.
  3. Good to know. Thank you.
