I have recently installed DivX 5, and ONLY the audio codecs of Nimo 4.4, and now when I do a DivX-> VCD (MPEG1) conversion, the MPEG1 is full-screened and it will not keep the same aspect ratio as before (i.e. letterbox)
I have uninstalled the Nimo codecs and tried downgrading to DivX 3.11, and it is still full-screening everything on the output MPEG1. I have made 5-6 VCDs from DivXs on this same machine with the same software recently and it kept the aspect ratio and did not full-screen everything (in other words, if the DivX played back in letterbox style, then the MPEG1-VCD would also playback in letterbox style)
This started happening after adding DivX 5 and the Nimo audio codecs. I've uninstalled both the audio codecs and DivX 5 and went back to just DivX 3.11, and it is still doing it! I am using the latest versions of Virtual Dub and TMPGe. Really going nuts here!
Results 1 to 10 of 10
Hit the "Settings" button in TMPGEnc then the advanced tab...
Look at video arrange method, and also anything checked in the list...
i have checked those settings, and no matter what i select (center, 1:1 VGA, etc) all of the mpegs come out to full screen - always, no matter what :cry:
If your using DivX 5, have you gone into its settings and changed something? On the General perimeters have you checked any of those boxes?
nothing is checked on my DivX 5.0 settings - just the defaults from when I first installed...like i said before, i uninstalled 5 and went back to 3.11 to see if it would work, and it is the same - everything full-screened.
Go to your control panel >multimedia > devices
What you got installed in there ? -
i have figured out the problem and the solution was setting the video arrange method (under advanced) to "fullscreen (keep aspect ratio)" with 1:1 VGA for the aspect ratio. i searched around the forum last night and found this info. i could have sworn that i tried this at one point and it didn't work, but i tried it again and all of the avi-mpeg conversions i've tried are coming out the right way now. 8) thanx
Latest Flash Player Beta Blue Screened My Machine
By Soopafresh in forum ComputerReplies: 3Last Post: 27th Nov 2009, 20:38 -
When converting VIDEO_TS to DivX, why is only the first file encoded?
By SheerGold in forum ffmpegX general discussionReplies: 5Last Post: 10th May 2009, 12:41 -
can't open mpegs made over 5 years ago - used tmpg
By heidihagen in forum Authoring (VCD/SVCD)Replies: 3Last Post: 20th Mar 2009, 15:40 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Cropping a divX encoded movie
By big_uk_ebuyer in forum EditingReplies: 4Last Post: 10th Jun 2007, 22:29
