I've been trying to render a video on sony vegas 12 for the past couple of days. Each time I render it 2 clips get partially lost. The sound remains, so does the text I inserted, but the video is gone. It happen specifically to 2 subclips I made. No matter what I play it in the black frames are still there. I'm rendering it as a 30 fps 720p 5000kbps .mp4 Does it matter that I unlinked the audio and visual? The other subclips play, so I don't think that's the issue. Does anyone know how to fix this?
did you try rendering with gpu turned off? try rendering with cpu only in the custom menu.
Honestly I've tried so many things I probably have, but i'll go do it now to be safe.
It doesn't work. In the preview screen while rendering when i get to those same frames the video goes out.
Make a support ticket with Sony.
That's very odd that you can see the video on the timeline, but not render it. Normally, WYSIWYG. Maybe the video has some timecode issue, or other unseen corruption, that affects it at render.
You can use AviDemux to transcode it to something else before importing to Vegas.
No, it doesn't matter that you unlinked the audio.Last edited by budwzr; 8th Jan 2013 at 20:35.
"Video: Stream attributes could not be determined" in Sony Vegas
By bloodshed in forum Newbie / General discussionsReplies: 41Last Post: 6th Nov 2012, 06:12 -
Sony Vegas "Black Screen" Issue
By Ruro Jiruries in forum EditingReplies: 7Last Post: 11th May 2011, 08:58 -
[Sony Vegas Pro 10] GPU "acceleration" = slower encode?
By DragonQ in forum Video ConversionReplies: 3Last Post: 11th Jan 2011, 15:32 -
Black Screen of Death in Sony Vegas Pro 9.0
By sonyvegaspunk in forum EditingReplies: 2Last Post: 29th Sep 2010, 21:37 -
Sony Vegas 9.0, AVCHD/mds "ghosting" with Canon HG10 footage
By Woodserr in forum Video ConversionReplies: 33Last Post: 29th Jul 2009, 22:12
