Ok. I installed DivX codec 3.11 alpha.
Installed SmartRipper & FlaskMpeg.
I ripped the DVD to my HDD
With FlaskMPEG converted the movie from MPEG2 to MPEG4 as i think using fast motion codec.
1st.) Problem is that when i play the AVI output file that FlaskMPEG produced i get AV desynch.
2nd.) Question. What must i do next to make a VCD . Should i convert the AVI file with TMPGENG 1.2+ to produce a Mpg file and then burn it with Nero??? I think i would get a larger file produced than the AVI ?? How am i going to fit it in a 80 min CD...?
Thanks a lot
http://www.vcdhelp.com/dvdtovcd.htm
Check out the above link to do rips. I use this method and I get GREAT quality vcds. -
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 00:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01
