Hi,
I have successfully burned BDMV folder on 4.7 GB DVD and PS3 recognizes it but same thing failed when i burn with Sony DVD+R DL 8.5 GB.The PS3 does not reads the double layer disc but when i play it on PC there is no problem.
Is there anything specific i have to do when i burn to double layer (8.5 GB) disc ? help me.
Thanks in advance
Results 1 to 28 of 28
most likely just poor media. there is still only one decent dl which is verbatim dvd+r dl.
"Sony DVD+R DL 8.5 GB" is poor media.
*** Now that you have read me, do some other things. *** -
Ok i will try with Verbatim but i cannot find one in my country.If i try to buy on ebay which model you recommend for ? any specific model number ?
I dont want to waste money on this so need your advice please. -
There are only two types of Verbatim double layer dvds that you should consider. Both are +R double layer (do NOT get -R dual layer discs).
The Verbatim discs that are rated for 2.4-6x are the older style and use the mid code MKM 001. If your dvd burner is more than five years old or so, this might be the better choice. The faster rated Verbatim +R DL is 8x speed and uses the mid code MKM 003. There really isn't much to choose between them.
If you can find some made in Singapore, those should be the best available. -
When someone says BD-5 or BD-9 they are probably talking about shrinking a BD disc or creating a BD structure small enough to fit on a DVD-5 or DVD-9 disc. I tried one of those when I first got a BDRom but only had a DVD writer a couple of years ago. I was surprised that with some tweaking using either BD Rebuilder or Ripbot264 (I can't recall) and patching the Index and movie files the full original menus and videos played on the PS3 on a S/L dvd disc.
I've used Sony S/L successfully but never tried Sony D/L discs so can't comment on your choice. For me Memorex (8x) and Verbatim D/L both work fine on the PS3. It may be the way you created the disc or the burning program. As suggested use ImgBurn. I don't know how you created your AVCHD but if my video file is already the right size for the disc and I don't need a menu I use tsMuxerGui to create a simple non menu AVCHD structure and burn the 2 folders (BDMV and Certificate) to a D/L disc with no problems on the PS3. If I want a home made menu or have multiple videos I want to access from their own separate menu I use MultiAVCHD. I'm no expert with it but that program has some nice features once you get the hang of it.
btw) I've been using "AVCHD Strict" when creating the disc using MultiAVCHD since the PS3 accepts it. It creates some extra folders so I just add them all to the burn folders in ImgBurn. Since I recently bought a BD burner I've also burned that structure on a BD-RE 25GB and BD-R 25GB and they also play well on the PS3.There's not much to do but then I can't do much anyway. -
That is a TERRIBLE idea. Why?
1) There is NOTHING to stop a person in Singapore from selling you Made In India Verbatim DL media. Where the seller lives has NOTHING to do with where what they sell was made. Think about it.
2) You'll pay extra for shipping if you don't live in the region.
3) It's just not that hard to find Made In Singapore DL Verbatims. I'll explain.
If you buy the faster Verbatim DVD+R DL discs, the 6x-10x ones, they are ONLY made in Singapore. The slower discs (the ones that top out at 6x and 2x-4x rated discs) are often made in India. The exception is that their DataLifePlus series of ink jet printable DL discs is rated at 2.4x speed but it's ONLY made in Singapore. -
In case of DVD+R DL you should look for "Verbatim DVD+R DL AZO" and they should be either MIS or MIT!
They are available as 2.4x rated discs (slowest possible speed for +R/DL!) and as 2.4x-8x rated discs.
In case you can find no +R DL media, you could also buy -R DL media by Verbatim. They are rated 1x-2x and 1x-8x....
DVD+R DL media is called Double Layer media, DVD-R DL is called Dual Layer media.
More info: http://en.wikipedia.org/wiki/DVD%2BR_DL
"One more question BD- 5 and BD -9 are actually DVD disks ? or specially made bluray disks ?"
Such formats doesnt exist. Maybe you meant AVCHD data on DVD media?!?
There is however BD25 (BD-R/RE) and BD50 BD-R DL/RE) but there is also BD-R TL and BD-RE TL (100GB) and BD-R QL (128GB).Last edited by [_chef_]; 8th Jan 2013 at 08:26.
mediarays - I give up. You are not understanding what you are being told. It's like this.
Me: Only buy X. Whatever you do, do NOT buy Y. ONLY BUY X!!!!
You: So you're saying to only buy Y.
I'm done here. Buy whatever the heck you want to buy. -
mediarays said
Did you read this note for the PS3 option in Multiavchd?Well.I have created using Multiavchd selecting PS3 option.I think only few people tried it on dual layer.Once i got verbatim i will burn again and post the results if that also fails then i stick DVD 4.7 GB.
Thanks for the help.
Why don't you try AVCHD (strict) I know that works.Output can be used with Playstation 3 if transferred to any solid state media - USB stick, USB HDD disk, SDHC, MMC or MemoryStick card.There's not much to do but then I can't do much anyway. -
Not all MKM 003 are made in Singapore. There have been, and continue to be some produced by Moser Baer in India. And they have been sold under the Verbatim brand, as well as a few others.
At one point, you could get very good quality MKM 003 discs made in UAE by FTI Falcon. The only ones I saw were sold under the Falcon Pro brand however, and I'm not sure they are still available. -
@mediarays, make a local call in your country (which?) to a reputable production company / dub house and just ask them where they get their bulk high-quality disc stock. I doubt they would have a problem letting you know (I know I don't when consumers ask me).
In the US, Rima.com is a good online/catalog supplier. You'll have to see what's available near you. Those that do "bulk" and "printable" rely on error-free, repeat pro business, so many of the brands/formalae are the better quality anyway.
One thing not mentioned, but you have to take into consideration, is that not just the filesize has to be lowered to fit on the disc, but the bitrate has to be lowered to both fit within the AVCHD spec (for DVDs) and to fit within the #x drive speed rating for the playback device chain. So, for example if you had a 1 hour title @ 40Mbps it would fill ~17.58GB of a BD. To get that down to 8.53GB (DVD-DL), you would have the lower the bitrate ~2.1x, giving you a 19Mbps bitrate (btw, this is still too high for AVCHD on DVD spec which maxes out at 18Mbps). But if your drive can ONLY play DVDs at 1x (11Mbps max), it will have continuous buffer problems. Those needing to fit onto a DVD-SL must by necessity lower it down to 9.54Mbps, so that already is within a 1x playspeed.
Now, most drives won't have this problem as they have been made more recently and probably can do 3x or more (if they are a combo BD/DVD/CD reader/player), but it still pays to take this into consideration.
Scott -
mediarays said
This makes little sense! Rather than playing with the avchd structure by renaming files and risking making an error why not just choose the right option that is proven to work in the first place?Yes you are right.That format only accepted on USB media and not on DVD so i stated i have renamed some files.
Good luck with this. I'm out!There's not much to do but then I can't do much anyway. -
It is sony's problem, can u please kindly try those disc with other bluray players, I hope those will work.
I have NEVER not even ONCE seen the 6x-10x DL discs made in India. EVER.
I stand by what I said and you can stand by yours. Let the readers decide for themselves. I am not a media code geek so perhaps we are not really comparing apples to apples here. And the DataLifePlus DL discs (whatever the hell their media code is) is ALWAYS made in Singapore. Always. NO EXCEPTIONS. So if you are talking about that being made in India, you are dead wrong. -
But did you tried those avchd's with dual layers working with sony bluray players or 3d bluray players.
If you look at what I wrote, it says "Not all MKM 003 discs are made in Singapore." The mid code is used by Moser Baer and sold under a variety of brands, including the Mirex, and Platinum brands and for a while you could also find these discs under the Verbatim brand (these were also designated the "Pearl White" variety). FTI Falcon also produced some MKM 003 discs and sold them under the Falcon Pro brand. All these MKM 003 discs were made using the Mitsubishi technology.
And if you look back through the tests of DL media in various spots over at MyCE, you'l find that MKM 003 discs sold under the Verbatim brand were also being produced in Taiwan.
At one point you could get Verbatim made by FTI Falcon, but I don't remember for certain if that included the MKM 003 discs or just the 16x single layer discs. If you want more definitive information talk to pepst or vroom over at MyCE, since they know the subject better than me.
All it takes is a bit of reading to be informed. Take a quick look through the last four or five pages of this thread: http://club.myce.com/f76/mitsubishi-chemicals-dvd-r-dl-97058/ There is quite a bit more evidence, but it takes more effort to track it down in the various burner threads.
AVCHD on hard drive: creating new AVCHD folder structure
By Phil_W in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st May 2011, 15:46 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 02:06 -
AVCHD to DVD: how to?
By taboo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 16th May 2010, 18:47 -
AVCHD to DVD etc.
By hperrier in forum Blu-ray RippingReplies: 4Last Post: 10th Dec 2009, 12:59 -
AVCHD to DVD
By h.k. in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2009, 00:38
