    Dec 2005
    Canada
    Using 32 bit AviSynth and plugin:this is the script:
    loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins\ffms2.dll")
    video = ffvideosource("C:\Users\Superuser\Desktop\clip.avi ")
    audio = ffvideosource("C:\Users\Superuser\Desktop\clip.avi ")
    AudioDub(video, audio)
    The .dll is installed in the Plugins folder, but VirtualDub errors out on it.
    The path to the source avi is good (I change the script to AviSource and it works).
Size:  10.3 KBClick image for larger version
  2. Are you using 32 bit VirtualDub?
    You can't use ffvideosource() to load the audio.
    Dec 2005
    Canada
    Yes, its 32 bit VirtualDub.
    Changed the script to this - same result.
    FFVideosource("C:\Users\Superuser\Desktop\clip.avi ")
  4. Are you using the correct version? (not the C plugin) ?
    regular
    http://code.google.com/p/ffmpegsource/downloads/detail?name=ffms-2.17.7z
    cplugin
    http://code.google.com/p/ffmpegsource/downloads/detail?name=ffms-2.17-cplugin.7z
    cplugin is for extra colorspaces in avisynth 2.6.x. It won't autoload. You need LoadCPlugin()
    Dec 2005
    Canada
    That was it - thank you.
    Four hours consistently downloading different versions of the wrong plugin didn't help.
    link update...
    Hi,
    Old thread, I know — but if this little update can help (to avoid hunting, like I had to):
    v. 2.17 32-bit:
    https://github.com/FFMS/ffms2/releases/download/ffms-2.17/ffms-2.17.7z
    v. 2.17 64-bit:
    https://github.com/FFMS/ffms2/releases/download/ffms-2.17/ffms-2.17-x64.7z
    Or whole page:
    Note (in reference to previous posts, above): make sure you download 2.17, not 2.2x or else, like I tried: didn't work for me either).
