    Jan 2013
    Norway
    HI,
    I have a DMTech dvd-901hd player and need to unlock the region on it. Can anyone help me?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Nobody here "makes" hacks. If your player is not listed here and you cannot find a hack with a Google search....you are out of luck.
  3. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    If region-free is so important to you, why did you buy a region-locked player?
    If an anti-lock braking system is important to you, you wouldn't buy a car without ABS, right?
    (Sorry, I had to throw a car analogy in there..)
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Simple.
    Rip it to region free and reburn. Or play the vobs with a media player like a wdtv media player.
    You're only problem will come into play if they are ntsc and pal issues. Though I've read (correct me if I'm wrong) that pal will play ntsc but I don't know for sure as I'm in ntsc land.
    If you have a player that can play pal and ntsc than all you have to do is rip the discs and burn em to blanks and you are all set.
    But this will have to be done with each and every out of region disc you have. That is if you can't find a hack for your particular model.
    ANd as previously stated you should look for a hackable model if that is that important to you. If its not too late try to return the model if this was a new purchase.
