So I took some footage using my EOS 600D from Canon, 1080p, 24 fps and all that Jazz. Got it onto my computer and it looked like something you'd see David Attenborough talking over (it was Macro woodland footage - moss and nettles and the like), I thought "Great! Time to cut it all together and stick some music over it!"
So I did.
All is well.
I got to the exporting stage, chose my settings I usually use:
Format : Windows Media
Preset : Custom (unchanged)
Output: C:\User\----\Videos\(Name of file)
1280x1080, Progressive
440kbps, 44kHz, 2 channel 24 bit VBR
Compressed, CBR, 1 pass, Audience:1, Max 256.00kbps (Could this be the problem?)
Source: Sequence, Sequence 01
1920x1080 (1.0), 23.976 (24) fps, Progressive, 00:02:21:20
48000 Hz, Stereo
Basic Video settings:
Codec : Windows Media Video 9
[ ] (unchecked) Allow interlaced processing
Encoding passes: 1
Bitrate mode: Constant
Frame width : 1280 pixels
Frame height : 1080 pixels
Frame rate : Same as source
Pixel aspect ratio: Square pixels (1.0)
[/] (Checked) Render at maximum Depth
Image quality 100
Decoder complexity : Auto
So with that in mind, when the video is finished, it looks absolutely terrible. Worse than that of 240p from youtube, for example. It's jumpy and is generally bad.
Where am I going wrong? All other videos I've produced have turned out fine
One thing i have noticed is that the encoding time races to around 50% and then slows right down to 'normal' so I'm thinking that has something to do with it.
Anybody got any solutions? I tried searching the web but nothing fitted my problem. Any help would be greatly appreciated.
Try ticking "match sequence settings" when you export.
1280x1080 is unusual, 256kbs waaaay too low. wmv is not a great output format anyway. See if that helps. -
first try using mediainfo on one of your canon .mov file. normal is 1920x1080p30 @50mbps. why did you change it to 24p? if anything in england it should be 25p for pal tv. and that output setting of 1280x1080 is just weird, it should be 1920x1080 or 1280x720. 256kbps might be ok for web video at 240x180 but even then it would look like trash. try for a minimum of 5 MBPS for HD 1080 to look good.
I feel like an Idiot. Even when typing this out I didn't spot it.
Many thanks for pointing this out! My computer is taking a longer, more re-assuring time to encode.
Thanks again!
Problem solved
Glad it worked out. Kinda remembered, 1280x1080 is a legitimate DVCPro anamorphic pixel format -- rarely used. I've never run across it in the wild.
Skippy/Jumpy Render output Issue Premiere CS5 to MPEG2
By dragan1975 in forum Video ConversionReplies: 8Last Post: 24th Dec 2011, 18:39 -
Premire Pro CS5 Export does not work with iPhone Anymore
By bowmah in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2011, 16:38 -
Premiere Pro CS5 Green Bar, Smooth Playback, Choppy Export
By bowmah in forum Newbie / General discussionsReplies: 10Last Post: 27th Jan 2011, 22:38 -
adobe premiere CS5 video exporting issue
By bteamstephen in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2010, 00:55 -
Export Multi Audio using Premier Pro CS5. How ?!
By SB4 in forum EditingReplies: 16Last Post: 21st Nov 2010, 03:08
