Okay, so, I am a HUGE fan of Nickelodeon's animated show, Robot And Monster. I am such a big fan that I want to make my own DVD of all the show's episodes. The episodes are all uploaded to Nickelodeon's servers, I have found them all and I want to download them. The problem is that all the episodes are embedded flash videos, and to access the video files themselves so I can download them, will require working with RTMPE stuff, which I know virtually nothing about. I need you guys' help for this. Granted, this will be no small task, as there are 26 episodes, each split into 4 segments that each have their own RTMPE link, so there will be quite a bit of work to be done. Are there any RTMPE experts here that are willing to get me the links to download these video files? You don't have to do all of it, you can do as much or as little as you want, but PLEASE help. If you do want to do some for me, just let me know and I'll give you the embedded video links to work off of. You guys are my only hope, and if any of you will help me out with this (for free), then there will be no words to describe how greatful I'll be. Please guys, I REALLY love this show! Thanks so much in advance for your help!!!!
P.S. For the record, Robot And Monster is an awesome show, but it can never come close to SpongeBob, the greatest show EVER, and which I am the world's #1 Fan of.![]()
if you can stream these and view them
I suggest you get replay video capture, and just do a screen capture recording
you can then edit them 'if needed' before making your dvd's
they can be captured in high bitrate mpeg2 / dvd format that does not require re-encoding
i suggest you capture at the Native resolution what ever it is, NOT screen zoomed -
Thanks so much for the response! Yes, I can stream the videos, but I don't really want to use a screen capture program for this. Sometimes, while streaming the videos, they'll pause for a few seconds to buffer, and I don't want that showing up on the DVD. I'd much rather download the videos directly by finding their RTMP stream links. Can you PLEASE help me with this? Also, is it possible to operate RTMPDump from a DROID 3 phone? Any help will be greatly appreciated. Thanks, guys!!!!
what part about the word 'edit' did you not understand
editing is how you remove the pauses, before you author the files into a DVD
sometimes screen capture is the only thing that will work
i understand frustration, and trying to have 'your / my way' sometimes we have to do it another way, not the way we prefer
IF i knew how to do it like you want, i would tell you, but I don't -
@CristianoA That's a good idea, but I'm looking for a way to do it on my DROID 3 Phone. I do appreciate the response.
@theewizard I'm not good with editing and stuff, so it probably wouldn't come out right if I tried that. Also, the quality isn't too great when streaming the video, but it is if I download it. And I know it's definitely possible to do it the way I want, I just need to figure out how to operate RTMPDump. I really appreciate your responses, though, thanks.
Actually, I just realized I don't need RTMPDump at all, because I just need the RTMPE link and I know what to do once I have that. And I can find this link with the program URLSnooper, which looks much easier to use. Now, is there any possible way of getting this program for my phone? I have a DROID 3 with Android OS 2.3.4. Thanks for the help!!!!
Ripping RTMPE or RTMPS encrypted streams?
By Hawwwh in forum Video Streaming DownloadingReplies: 0Last Post: 4th Dec 2012, 09:30 -
Is Youtube Using RTMPE?
By tworegon in forum Video Streaming DownloadingReplies: 14Last Post: 31st Aug 2012, 15:43 -
Combining MP4 files downloaded via rtmpe
By Cwluc in forum EditingReplies: 2Last Post: 4th Feb 2012, 22:37 -
Help / 2nd opinion / advice needed from video experts - See attached Images
By sanchopanza in forum Video ConversionReplies: 5Last Post: 18th Mar 2011, 16:22 -
Pioneer 508XD experts needed!
By bjur in forum Media Center PC / MediaCentersReplies: 2Last Post: 22nd Jul 2008, 05:42
