Hamood: I'm gonna help ya out on what tools everyone should use. The number one ripper is made by Fengtao software, DVDFAB Ver. 8.2.2.6 or greater in 8 version. Note that 9 is still beta and is only recommended for advanced users.
I use Image Burn Imgburn to convert the VTS.VOB files into an ISO image because Image Burn removes majority of the garbage files being minor encryptions that FAB does not detect...such as encryptions that causes stand alone media players like WDTV HD players to power down. Imgburn picks up where DVDDecrypter left off. Now Imgburn will not remove CSS and other copy protections unless you have fabpasskey running in the background or older on the fly such as DVD43 or other background decrypters.
Keep the ISO images as they can easily be burned to disc or re-decrypted using any version of FAB 8 or greater.
I use Nero Recode 2 for burning DVDs which I no longer burn to disc as I now use HDDs, as I have built my own free nas servers.
makemkv comes more in handy with fixing broken .M2TS files. Makes it easier for merging.
				Results 31 to 35 of 35
	CloneDVD mobile used in conjunction with AnyDVD. Select the VOB File (passthrough) profile in CloneDVD mobile.
	THANKS dvdsham your awesome and the other people helped me a looot
 but you see i have 100+ DVD movies or more im still counting, i cant do what you say in every single one too much time consuming..right
 and for makemkv as you see i have merlin Pocket HDD 1TB which doesnt support MKV, if it was i would make my own DVD using MKVToolNix but its too late
 But i will try it on other one if i found the same problem, i still have many movies
 when i try your way i will tell you how it goes
	Have you tried using the Pocket HDD to play MKVs? Is this the one you have?
 http://merlin-digital.com/pocket-hard-disk-full-hd.html
 It doesn't list MKV under specifications but the description says: "FULL HD DIVX/MKV Player and Pocket USB Hard Disk"
 The manual is basically useless as it doesn't tell you anything.
	merlin Pocket HDD supports MKV, it should still work unless it needs to be remux.
  Dvd with subtitles and Audio tracks in one big vob file help convertingBy jimbobob84 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 03:09
  Not being able to rip BD with newer versions of DVD FabDecrypter6.2....By cal_tony in forum Blu-ray RippingReplies: 6Last Post: 13th Nov 2009, 07:47
  Do newer drives rip dual layer discs any faster?By Sephiroth666 in forum DVD & Blu-ray WritersReplies: 3Last Post: 21st Feb 2008, 10:40
  how can I rip my dvd tracks to individual .VOB file?By dannieboiz in forum DVD RippingReplies: 6Last Post: 16th Jan 2008, 21:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
