I have more than 100+ DVD movies some of them is old and i ripped them using DVD Decrypter which it gave me 1 IFO file and 1 BIG VOB file with all audio tracks and all subtitles and it works perfect because i want to play them in my Merlin Pocket HDD.
Now i have newer DVD which DVD Decrypter wont work with it, i tryed AnyDVD with DVD Decrypter and DVD Shrink and no luck.
I tried AnyDVD but it wont give me an option to extract IFO file and 1 VOB, it rips everything which too much time consuming and more than 1 VOB file which is not what i want
i also tryed DVDFab 9 its the same as AnyDVD
I tried to join the VOB using some programs but its very bad some of the movies runs 2 hour after joing it give me 1 hour
All i want is to do the same as DVD Decrypter which i chose The main movie and IFO and rip them with 1 IFO file and 1 Big VOB file.
can anyone help me or guide me?
Results 1 to 30 of 35
What happens when you use anydvd and run dvd decrypter?
Use AnyDVD to rip to an ISO image.
Mount the image with Daemon Tools Lite.
Open the mounted image with DVDDecrypter.
But copying the disc to your hard drive MOVIE ONLY with DVDFabDecrypter then using VOB2MPG would be much easier. -
The OP stated it rips with anydvd & dvdfab but give him the usual dvd structure instead of 1 vob, which dvd decrypter will do but chokes on the newer dvd.
The 2 options hech listed are pretty much it. -
this is the error it gave me
the same error when i use DVD Decrypter with or without AnyDVD
Yes hech54 i tried to backup iso using AnyDVD then use DAEMON Tools Lite then use DVD Decrypter it gave me same error
i noticed when i ripped the main movie using AnyDVD it gave me length like this
VTS_01_2 00:24:24
VTS_01_3 00:24:50
VTS_01_4 25:33:43
VTS_01_5 00:22:21
VTS_01_6 00:21:19
VTS_01_7 00:02:42
the movie is "Das Parfum Die Geschichte eines Mörders"
www.imdb.com/title/tt0396171
its a 2 hour movie why in VTS_01_4 its 25:33:43 ?
does anyone know?
Also same DVD movie called "Die Päpstin" same thing both have the same thing
www.imdb.com/title/tt0458455Last edited by hamood_d10; 3rd Jan 2013 at 15:34.
They were both released by the same production company, I still think it's copy-protection.
its a two movies and the two movies are different DVD and film lol
and my HDD is brand new 1TB WD i have no problem hech54
they are from same company indeed
yes i guess they are copy-protection but how to rip them i need help, i ripped 26 movies till now using DVD Decrypter with no problem
ANYONE CAN HELP ME?Last edited by hamood_d10; 4th Jan 2013 at 04:40.
Does it play with the VOB structure? That is has it been succesfully decrypted?
If so THEN use DVD Shrink on it to save the main movie as a single VOB. Though when I do that I have found some players do not like a single VOB and stop at the 1GB limit. -
Go to DVD Shrink - Edit - Preferences - Output File Tab
Split VOB files into 1GB size chunks (recommended).
Uncheck the Box
Trying it with Blood Simple Full Disk
Original file structure
Directory of F:\DVD\BLOOD_SIMPLE\VIDEO_TS
01/04/2013 07:06 AM <DIR> .
01/04/2013 07:06 AM <DIR> ..
01/04/2013 07:06 AM 0 list.txt
09/26/2012 11:59 PM 20,480 VIDEO_TS.BUP
09/26/2012 11:59 PM 20,480 VIDEO_TS.IFO
09/26/2012 11:59 PM 303,104 VIDEO_TS.VOB
09/26/2012 11:59 PM 69,632 VTS_01_0.BUP
09/26/2012 11:59 PM 69,632 VTS_01_0.IFO
09/26/2012 11:59 PM 1,044,480 VTS_01_0.VOB
09/26/2012 11:59 PM 1,073,739,776 VTS_01_1.VOB -- Five VOBs
09/26/2012 11:59 PM 1,073,739,776 VTS_01_2.VOB
09/26/2012 11:59 PM 1,073,739,776 VTS_01_3.VOB
09/26/2012 11:59 PM 1,073,739,776 VTS_01_4.VOB
09/26/2012 11:59 PM 251,455,488 VTS_01_5.VOB
09/26/2012 11:59 PM 14,336 VTS_02_0.BUP
09/26/2012 11:59 PM 14,336 VTS_02_0.IFO
09/26/2012 11:59 PM 288,768 VTS_02_1.VOB
09/26/2012 11:59 PM 14,336 VTS_03_0.BUP
09/26/2012 11:59 PM 14,336 VTS_03_0.IFO
09/26/2012 11:59 PM 27,033,600 VTS_03_1.VOB
18 File(s) 4,575,322,112 bytes
Directory of G:\VIDEO_TS
01/04/2013 07:02 AM <DIR> .
01/04/2013 07:02 AM <DIR> ..
01/04/2013 07:02 AM 0 list.txt
01/04/2013 07:00 AM 20,480 VIDEO_TS.BUP
01/04/2013 07:00 AM 20,480 VIDEO_TS.IFO
01/04/2013 06:53 AM 303,104 VIDEO_TS.VOB
01/04/2013 07:00 AM 69,632 VTS_01_0.BUP
01/04/2013 07:00 AM 69,632 VTS_01_0.IFO
01/04/2013 06:53 AM 1,044,480 VTS_01_0.VOB
01/04/2013 07:00 AM 4,546,412,544 VTS_01_1.VOB One single VOB instead of five
01/04/2013 07:00 AM 14,336 VTS_02_0.BUP
01/04/2013 07:00 AM 14,336 VTS_02_0.IFO
01/04/2013 07:00 AM 288,768 VTS_02_1.VOB
01/04/2013 07:00 AM 14,336 VTS_03_0.BUP
01/04/2013 07:00 AM 14,336 VTS_03_0.IFO
01/04/2013 07:00 AM 27,033,600 VTS_03_1.VOB
14 File(s) 4,575,320,064 bytes
Trying it with Blood Simple Main Movie in Re-author
My this one is excitingly complex
Directory of G:\Blood Simple\VIDEO_TS
01/04/2013 07:10 AM <DIR> .
01/04/2013 07:10 AM <DIR> ..
01/04/2013 07:10 AM 0 list.txt
01/04/2013 07:09 AM 6,144 VIDEO_TS.BUP
01/04/2013 07:09 AM 6,144 VIDEO_TS.IFO
01/04/2013 07:09 AM 61,440 VTS_01_0.BUP
01/04/2013 07:09 AM 61,440 VTS_01_0.IFO
01/04/2013 07:09 AM 4,546,412,544 VTS_01_1.VOB - Again one single VOB plus the IFOs and BUPs.
6 File(s) 4,546,547,712 bytes
Pot player does not play nice with the full disk version after conversion to a single VOB, works normal with the original. I couldn't get it to advance but it played right at the start. Might have stopped when I got the 1 GB mark but that would take about 20 minutes to find ouit. VLC was OK with it as far as I could tell. Chapters and seeking worked.
Same for the movie only version. Flaky at best in Pot player and working right in VLC. -
Try RipIt4Me. I've only come across the same error once when using AnyDVD to decrypt DVDs and trying to open them with DVDShrink, but RipIt4Me worked fine (AnyDVD still decrypting). Once Ripit4Me has done it's thing and opened DVD Decrypter to rip the disc you should be able to change the DVD Decrypter settings yourself if need be. Well I don't see why not. Alternatively RipIt4Me has a "movie only" mode if that's what you're after. It can't hurt to try.....
I tried DVDShrink it takes too much time while i hear the DVD sound then after like 5 minute it tells me there is no disk
BTW i have LG DVDRAM till now i ripped around 300GB in 66 Movies with no problem and i tried DVDShrink in other DVD it works FINE.....SO NO PROBLEM IN MY DVDRAM OR HDD OK
i will try RipIt4Me and give you feedbackLast edited by hamood_d10; 4th Jan 2013 at 15:52.
I used RipIt4Me its just using DVD Decrypter!!!!!!
same thing man nothing change i thought its other program..........
DOES ANYONE KNOW BECAUSE THOSE 2 DVD DRIVING ME CRAZY !!!!! -
It's just some sort of structural copy protection. Mostly it's not a problem and chances are sooner or later AnyDVD will be updated and DVD Decrypter will be able to rip those discs with AnyDVD running in the background again.
I know Ripit4Me uses DVD Decrypter, which is why I said RipIt4Me will do it's thing then open DVD Decrypter, but RipIt4Me does the analysing and in my case that allowed DVD Decrypted to load the RipIt4Me file and rip the disc, but unfortunately that didn't work for you.
The suggestion by someone else earlier to use DVD Shrink wasn't to open the disc but to re-author it after AnyDVD has ripped it. AnyDVD should rip them fine (although I think you said it already has) and then you can just open the ripped files using DVDShrink as you would the disc. Go into it's options and tell it not to split vob files, set the target output size to something huge so it won't try to re-encode the video when re-authoring it, open the ripped files, use the re-author button and drae the main movie from the right pane to the left pane. Use DVDShrink's backup function to save the re-authored version to a new location on your hard drive and you'll have a new set of DVD files including the single large vob file you're after.
Yes it'll take a bit longer than opening the discs directly and re-authoring them while ripping, but it's only two discs. -
EDIT: You can also Try running DVD43 or FABPASSKEY in the background while using Image burn.
Try Image Burn http://www.imgburn.com/
If you are using AnyDVD, you should send a error report to Slysoft and hope that they update the copy protection. I have used AnyDVD for the last 5 years or more and have had very good results. I have used Imgburn, CloneDVD, and DVD shrink with AnyDVD without a hitch. Sounds like it is the disc makers protection making you have such bad out come.
If it feels good, do it. -
hech54: Where is the option to output something to a single VOB in DVDShrink?Originally Posted by Ethlred
If so THEN use DVD Shrink on it to save the main movie as a single VOB.Ahhh, an excellent example of the true meaning of VideoHELP: Someone provides someone else with an exact answer to their question without making any snarky comments about how long the information seeker has been a member of this board and, therefore, should have known the answer already.hech54: Ahhh....I was looking for it in the settings "Backup" settings.Originally Posted by Ethlred
Uncheck the Box
Superb!!
Old axiom: We are all ignorant, just on different topics.
OK guys
I Ripped the DVD with AnyDVD which it ripped everything (too much time dah) with no problem
I did like what hello_hello said i opend DVD Shrink and re-author and chose MAIN MOVIE in the folder location then i chose not to split files
it gave me 1 IFO and 1 VOB file for the movie which is what i want, ALSO THEY PLAY FINE IN MY POCKET HDD
...only one problem
The movie length is 02:21:28
when played with VLC it gave me 01:05:58 but it playes fine till the end
tried other players same result
WWHY IT GAVE ME THIS PROBLEM?Last edited by hamood_d10; 5th Jan 2013 at 05:30.
hamood: Download DVDFAB 8 at the following link: http://www.dvdfab.com/download.htm Also look at the inner circle of the DVD on the read side to see where the disc is manufactured to ie: mexico, usa, france, canada...and so on. If the rip fails report it at https://www.facebook.com/dvdfab?ref=ts&fref=ts and wait for Fab media staff to reply.
i bought them from germany
OK but what does DVDFAB to do with anything?
i used only AnyDVD and DVD Shrink ONLY -
Hamood: Just to let you know Fab 9 is still in beta stages where Fab 8 is more stable than 9. We're only trying to help you out. It was myself that discovered different - new types of encryptions by country are coming into role. I reported my discovery to Fab over 1 year ago as now they have confirmed it.
Dvd with subtitles and Audio tracks in one big vob file help converting
By jimbobob84 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 03:09 -
Not being able to rip BD with newer versions of DVD FabDecrypter6.2....
By cal_tony in forum Blu-ray RippingReplies: 6Last Post: 13th Nov 2009, 07:47 -
Do newer drives rip dual layer discs any faster?
By Sephiroth666 in forum DVD & Blu-ray WritersReplies: 3Last Post: 21st Feb 2008, 10:40 -
how can I rip my dvd tracks to individual .VOB file?
By dannieboiz in forum DVD RippingReplies: 6Last Post: 16th Jan 2008, 21:27
