Trying to use the Honestech VHS to DVD 5.0 Delux. I downloaded the software as required, did all the connections on the capture device as recommended but as soon as I try to use it I get the following message. "No capture device detected. Please connect the capture device before using honestech 5.0 delux".?? I've disconnected and reconnected I don't know how manny times but I still can't get it to work and get the same message over and over??? I'm using i7-3770 processo and USB Ports 3.0. I notice that the instructions mentions to connect to the USB 2.0 port. Could this be where the problem is or should it work with 3.0. Port. If anyone can help me on this I would appreciate it. I hope I posted in the right place. Tks.
Is that the software that comes with your noname capture device?
VHS to DVD conversion - Am I expecting too much?
By Office Linbacker in forum Capturing and VCRReplies: 163Last Post: 2nd Apr 2014, 11:56 -
VHS to PC for conversion to DVD
By EJ8 in forum Capturing and VCRReplies: 6Last Post: 15th Jun 2009, 21:49 -
VHS to DVD - is there any way I can improve quality of conversion?
By rairjordan in forum Capturing and VCRReplies: 21Last Post: 13th Feb 2009, 13:32 -
By gallootjs in forum MacReplies: 7Last Post: 7th Mar 2008, 09:44 -
By elia12978 in forum Capturing and VCRReplies: 16Last Post: 13th Jan 2008, 18:42
