My Sony blue ray player [BDP-S380] can not play this MP4 file:
MediaInfo:
General
Complete name : C:\Users\user1\hd_001.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 886 MiB
Duration : 25mn 1s
Overall bit rate : 4 951 Kbps
Writing application : Lavf54.25.105
Comment : FlixEngineLinux_8.0.14.0 (www.on2.com)
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : avc1
Duration : 25mn 0s
Bit rate mode : Variable
Bit rate : 4 868 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.078
Stream size : 873 MiB (98%)
Writing library : x264 core 128 r2216 198a7ea
Encoding settings : cabac=1 / ref=16 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=abr / mbtree=1 / bitrate=4868 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2012-10-07 09:22:37
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 25mn 1s
Bit rate mode : Constant
Bit rate : 68.9 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 12.3 MiB (1%)
It plays other MP4 files [AVC high@4.0] [CABAC / 2 Reference Frames] without any problem.
All these files play perfect on my PC.
For me it seemed the only difference is the number of Reference Frames, so it appeared that my player (a few years old) can not deal with a high frame number.
I managed to change AVC level from 5.1 to 4.0 using TSMUXER, my player loaded and played the resulting file but it was full with blocks and discolored so it was useless.
So now I need to change the Ref Frames from 16 to a lower number. I have googled for a solution but no luck.
I would appreciate any advice and comments
Thanks all
	Thanks poisondeathray for your reply.
 Looking through Google, I tried this script:
 ffmpeg -i old.mp4 -c:v libx264 -profile:v baseline new.mp4
 The input file was about 188 MB. It took about 6 minutes to produce the new file ( on a core i7), so I assumed some re encoding had been done. The output file was 335 MB, but it did work in my player with almost the same quality.
 Now I have to deal with about 200 MP4 files, each with an average of around 1 GB.
 So what are my best options to achieve that? a part from buying a brand new player which would accept 16 Ref Frames.
 Is it possible to improve on this ffmpeg option or some other program to make faster?
 Thanks again.
  Editing MP4 files with H.264 (AVC) video and AAC audioBy Ahari in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2012, 17:30
  Change avc level and reference frameBy cote112 in forum Video ConversionReplies: 2Last Post: 24th Mar 2011, 11:45
  Joiner / Editor for H.264 AVC MP4 filesBy nickb23 in forum EditingReplies: 8Last Post: 7th Aug 2009, 06:56
  MP4 AVC/H.264 encodingBy Jacobus Serpenti in forum Video ConversionReplies: 17Last Post: 1st Jan 2009, 09:18
  vegas/ffdshow/avidemux: avc-mp4 encoding for playback in Flash playerBy mindplay.dk in forum Video ConversionReplies: 21Last Post: 1st Jun 2008, 18:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
