Hello Everyone. I have downloaded films from morpheus. They are in avi format. Can someone help I want to view them on a playstation & DVD player. How would I do this. The dvd is compatiable to take copies. Any help appriciated
Regards Tony
Boy, you're gonna have to give us a lot more info. What format do you want to use? Being a VCD site, I imagine you should do this format. For Playstations to play VCDs, you would need to get an additional hardware module for it first. Playstation2s cannot play VCDs. To convert AVIs, use TMPGenc for encoding.
if you downloaded the avis from morpheus, they are likely divx. go and read the "convert" section under HOW TO for divx -> vcd.
dv cables help required
By rizvi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 18th Mar 2009, 03:05 -
Codec Required
By booyaka in forum DVD RippingReplies: 4Last Post: 15th Dec 2007, 02:58 -
Help Required. Capturing DV to PC
By jeffbhoy in forum Newbie / General discussionsReplies: 10Last Post: 21st Jun 2007, 18:37 -
Software Required
By dbanga in forum ProgrammingReplies: 2Last Post: 15th Jun 2007, 06:47 -
Advise Required
By dbanga in forum EditingReplies: 6Last Post: 4th Jun 2007, 16:57
