    Dec 2012
    Malaysia
    Hey ,
    can someone help me how to batch converting Vorbis (.ogg) to AAC (.mp4)
    Maybe some tool or avisynth script, that function like on MEGUI
    THanks
    Try the new taudioconverter.
    Dec 2012
    Malaysia
    why doesnt it support neroaac?
    You can also try LameXP.
  5. should also work with Hybrid:
    • start Hybrid
    • set you output folder (Config->Path->Output Path)
    • set Audio handling to 'auto add (all)'
    • enable: Audio->Main->Reencode audio stream
    • configure the audio reencoding (aac can be encoded through: ffmpeg, qaac*, FHG**, NeroAacEnc***)
    • switch to the Main-tab and drag&drop all you files to the input slot (or press 'File input' and select the once you want to reencode)
    • enable automatic output name generation (Main->Generate)
    • if you want the output to be iTunes compatible (e.g. named .mp4a enable: Config->Output->Container Settings->Mp4 settings->iTunes compatibility)
    • add jobs to queue (press Main->Add to Queue)
    • start processing (press main->Start Queue)
    * requires Quicktimes Application Support to be installed (comes with iTunes and Quicktime)
    ** requires WinAmp to be installed or the aac encoder libraries to be copied into the Hybrid folder
    *** requires NeroAacEnc
    Personally I would use qaac for encoding audio.
    Cu Selur
