My input videos are either 720p @ 59.94fps or 1080i @ 29.97fps (from TV). I would like to use ffmpeg to decimate that down to 23.976, but the -r 24000/1001 command returns a choppy video. If I run the original atsc video through avisynth with TDecimate(cycle=2).TDecimate(cycle=5) or the ntsc with just TDecimate(cycle=5), I get the 23.976 and it isn't choppy. Is there any way to use ffmpeg to smoothly decimate the video like with avisynth?
So, the obvious question: if avisynth works, why not use it? But, to address your specific question:
I've been recently disappointed with ffmpeg, specifically producing telecined content (29.97fps playback) from 23.976fps source. After pulling my hair out and even trying ffmbc, I found that mencoder did everything I wanted and more.
mencoder does have a decimate filter, although the documentation describes it in a somewhat different use case. Just for kicks, try mencoder with -ofps 24000/1001 to see if it does a better job reducing framerate.
Also, consider using the latest git/svn of either ffmpeg or mencoder. I've found vastly different performance by changing versions to stable/bleeding/devel/whatever.
convert 50p and 59.94p 264 to 1080 25i and 1080 29.97i
By wiseant in forum Video ConversionReplies: 8Last Post: 13th Aug 2012, 17:02 -
What To Do with 1920 x 1080 \ 59.94p Footage When in multiAVCHD?
By bmccollum in forum Authoring (Blu-ray)Replies: 3Last Post: 19th Oct 2010, 10:56
