you need three programs.
One is called OSex. It removes any and all encryption on the disc and saves .VOB files to your hard drive. Here is a link to download:
http://www.cse.Buffalo.EDU/~afaversa/test/osex-0.0101a4.sit
Then you need these two utilities to decode the video and audio fom the VOB files. They are BOTH at:
http://homepage1.nifty.com/~toku/software_en.html
Then you need to combine the resulting audio files/chapters [supports MP3] in quicktime and do the same for the video.
Then you copy the entire sound track to the clipboard and tell it to ADD SCALED to the video track.
You can then export the resulting movie to Video CD, quicktime, or if yo uhave right codecs, DiVX.
Process takes about a day to complete on a good G4.
I have tried decoding the video using a number of codecs, including Sorenson, but i have found that the best one to use it Motion JPEG A at maximum quality.
Feedback please.
Results 1 to 1 of 1
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
Dvd rip(HD) in mac - Mov,mpg,avi
By nimrodm in forum MacReplies: 3Last Post: 9th Feb 2010, 07:33 -
Mac format HD DVD, How can I rip?
By haymes in forum Newbie / General discussionsReplies: 16Last Post: 22nd Mar 2009, 16:45 -
Tool to Rip a DVD on MAC for backups?
By fiiido in forum MacReplies: 6Last Post: 22nd May 2008, 07:29 -
New Mac user: Looking to rip, compress and burn DVD's on iMAC
By Jabroni4872 in forum MacReplies: 6Last Post: 12th Apr 2008, 21:53
