I have read on slashcam, that the 4:2:2 codec in the Canon HF G10 camcorder is not activated. Is it possible to activate it somehow? I know that in case of some devices you can use a custom boot software, that unlocks the software based restrictions. I saw such a software for the Canon Eos 550D. It simply added a lot more menu options with possibility for much refined settings, for example for white balance, etc. I wonder if such an unlock software exists for the Canon HF G10 to activate the 4:2:2 codec. Is there any like that?
You're thinking about Magic Lantern Firmware hack for canon DSLRs. Although it introduced a lot of control like compression and framerate options, it won't let you change the color space to 4:2:2. Not as of the last version I tried anyway.........
Your best bet is to do some searching for "canon hf g10 firmware hack" and see what comes up. Good luck.......Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
for canon magic lanterned dslrs you can record 422.
Silent Pictures
This feature is reserved to very advanced users. It can take pictures in LiveView mode without moving the mirror. When enabled, it saves uncompressed YUV422 frames from the LiveView image buffer when you press the shutter halfway.
- Make sure you don't have autofocus assigned to half-shutter press (put it on * or turn it off)
- Silent Picture: simple, low-resolution. Image resolution is usually around 1 or 2 MPix, and depends on the current mode (zoom or not, recording or not, and movie resolution). For almost-FullHD resolution (1720×974), choose FullHD to record a dummy movie.
Choppy playback on computer for a HF G10
By icoolyou in forum Newbie / General discussionsReplies: 2Last Post: 24th Feb 2012, 13:29 -
Using wireless mic with shotgun mic on Canon HF G10
By jimleben in forum AudioReplies: 5Last Post: 23rd Jan 2012, 21:11 -
Canon VIXIA HF G10
By wingspar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 12th Dec 2011, 17:18 -
Working with HD video from Canon EOS 550D - missing codec?
By stustjohn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 23rd Jul 2011, 06:00 -
Canon HF G10 / XA 10 Questions
By Altzone in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 8th Jul 2011, 12:11
