Can someone tell me the difference between the master bus and the volume slider on the audio track? Must I keep them both at 0.0db? I can't seem to get the volume right.
you only need a master bus for surround sound. and no you can adjust the sliders wherever you need to. neither one means the encoded output will be at 0db.
Hello..been a long time-Can I upgrade from vegas 5.0 and DVD arch 2.0 to Vegas Pro 9
By arcorob in forum Newbie / General discussionsReplies: 6Last Post: 1st Feb 2010, 20:31 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 00:41 -
All-in-One Volume Control? Vegas 6
By solarblast in forum AudioReplies: 2Last Post: 6th Dec 2008, 09:07 -
Sony Vegas 9.0 Platinum how do I raise and lower the volume?
By LoveMyslf in forum EditingReplies: 1Last Post: 7th Nov 2008, 12:28 -
Vegas 8 volume envelope help
By stantheman1976 in forum AudioReplies: 3Last Post: 22nd Jun 2008, 21:29
