My Panasonic DMR-EH59 does not have inputs for HD, just RCA cables. I'm transferring movies recorded in HD from my Directv HD receiver to my Panasonic but get a warning across my screen "Your TV or its cables are not HD!"
At a minimum, I would like to be able to keep this message from appearing. Are there higher grade cables I could be using to make this message go away? Can you use component cables with RCA inputs?
Your DVD recorder is not HD, regardless of what cables you use. There might be a menu item on your receiver to turn off the messages.
OK, thanks. The message goes away by itself after several seconds but it would be nice not to see it at all.
Are there DVD recorders out there yet that will record to a disc in HD?
RCA 42 inch RCA LED42A45RQ - Horrible Sound.
By HoosierGuy in forum DVB / IPTVReplies: 10Last Post: 13th Dec 2011, 21:23 -
RCA composite video on Wii but component video and VGA inputs on tv
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 22:48 -
Looking for a DV camcorder with AV inputs
By aussiebloke in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 18th Apr 2010, 01:29 -
can receive feedfrom rca leads but not via scart to rca lead
By deanno in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2009, 11:39 -
Gateway LX6810-01 with RCA inputs, how to use?
By Gotmilk0112 in forum Newbie / General discussionsReplies: 6Last Post: 30th Jun 2009, 01:37
