  1. Hello,
    I'm having trouble getting the playhead (I think that's what it is called) to work in MPEG Streamclip. There is a black bar where it should be.
    The bar that helps you 'play' and pause videos to select in and out.
    I have attached a photo as example.
    The only way I have been able to select IN and OUT is using the lower buttons/use the keyboard.
    I would appreciate some help.
    Thankyou
