I entered a code 9113 into my DVD player in an attempt to change the region code from 1 to 2
Now it will not play any discs
Can anyone help how to get back to play region 1
	I have this model. The code does not break the player. So either you have a problem that the player is defective or maybe you are trying to play discs that aren't region 2. If you don't remove all power from the player the Configure Player menu should still be there and you can just go in and change the region to whatever you need. If you don't see the Configure Player menu option then follow the same hack instructions you did before to make it visibile.
 Note that we get a lot of new members who ask for help on various things and they leave out critical bits of information. If you upgraded the firmware after you changed the player to region 2 and you didn't tell us, I suppose that could have unintended consequences. Well, assuming you haven't upgraded the firmware you could just disconnect the player from power and that will make it fall back to region 1 (DVD) and region A (BluRay) mode automatically, but it will also remove the Configure Player menu option and you'll have to redo the hack to make it visible again.
  Insignia NS-WBRDVD3 downgrade for region free?By menash23 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Jan 2012, 23:05
  Region Code Hack for Insignia NS-P10DVDBy salmon73 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 14th Nov 2011, 13:38
  Insignia IS_DVD040924 Region code?By tedowden in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Apr 2009, 14:56
  need region code for Insignia NS dvd 1-A playerBy gegely in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Mar 2009, 18:05
  Insignia ns-fs Dvd hack codeBy guest gm in forum Newbie / General discussionsReplies: 5Last Post: 20th Feb 2009, 22:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
