Hi all,
I'm planning on remuxing bluray to either .ts or .mkv. I just need help deciding which one is better.
I plan on using Clown_BD to demux the bluray file and remux into either a .ts file or use mkvmerge to remux to .mkv.
I will keep the main movie file, main English audio file and English subtitles in PGS format.
I will play from my computer using Media Player Classic into my TV via HDMI cable. Or from my external media player into my TV via HDMI.
Does either .mkv or .ts have any specific advantages over the other to make it worth it?
TS containers can only hold video and audio that is valid for BluRay. MKV can hold essentially anything. To put it in practical terms, AAC audio is invalid for TS but legal for MKV. I would recommend MKV because it has fewer restrictions on what it can hold, but if you are just going to be working from BluRay sources then TS can meet your needs fine. You might just make a test TS file and if t meets whatever playback needs you have, continue on at that point.
Have you ever read the transport stream specification ?TS containers can only hold video and audio that is valid for BluRay.
How do you explain that:
a. even DVB allows aac audio and some countries use it (https://en.wikipedia.org/wiki/Digital_Video_Broadcasting) ?
b. vlc supports using transport stream with a variety of formats (http://wiki.videolan.org/MPEG#TS.2C_MPEG2_Transport_Stream) ?
I agree that mkv is the better container (mainly because of lesser container overhead and better content indexing). -
I'm pretty sure Clown_BD won't rip encrypted discs, so you'd need something like AnyDVD HD running in the background decrypting which isn't free. Unless there's a free AnyDVD alternative.
I use HD-DVD/Blu-Ray Stream Extractor and rip the video as MKV but you'dl still need to remux the audio and subtitles when it's done. It's probably very similar to Clown_BD (I haven't used it for a fair while) but once again it requires something like AnyDVD to do the decrypting.
Bluray Remux + Hardcoded non-English parts
By Mr_X2012 in forum Blu-ray RippingReplies: 7Last Post: 6th Sep 2012, 06:26 -
Blu-ray to MKV remux
By axl70 in forum Blu-ray RippingReplies: 5Last Post: 11th Nov 2011, 08:44 -
80% MKV remux on H.264 - M2ts remux Aero Theme
By BJ12 in forum Video ConversionReplies: 2Last Post: 12th Aug 2011, 13:59 -
MKV with MKV Merge Unicode not compatible with LG BluRay Player
By klode in forum Video ConversionReplies: 3Last Post: 8th May 2011, 04:42 -
Bluray remux and Bluray re-encode question
By mocqueanh in forum Blu-ray RippingReplies: 4Last Post: 22nd Feb 2011, 21:25
