Results 1 to 11 of 11
  1. I have a video which was taken with an iphone and then sent from a Mac pc to mine which is windows 7, and i can not read it or edit it. I want to edit it but i''m not capable of doing so because it's format is .MOV, i tried many times to convert it to .mp4 or .avi but nothing seems to work. If anyone could answer me i would appreciate it. Thank you in advance.
  2. MOV is a container. What codec is being used? Use mediainfo (view=>text)
  3. General
    Complete name : C:\Users\Home\Desktop\IMG_2008.MOV
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 21.4 KiB
    Duration : 43s 380ms
    Overall bit rate : 4 035 bps
    Recorded date : 2012-12-27T16:11:43+0100
    Encoded date : UTC 2012-12-27 15:11:43
    Tagged date : UTC 2012-12-27 15:11:56
    Writing application : 6.0.2
    Writing library : Apple QuickTime
    com.apple.quicktime.make : Apple
    com.apple.quicktime.creationdate : 2012-12-27T16:11:43+0100
    com.apple.quicktime.location.ISO6709 : +43.7440+007.4249+105.888/
    com.apple.quicktime.software : 6.0.2
    com.apple.quicktime.model : iPhone 5
    Model : iPhone 5
    ©xyz : +43.7440+007.4249+105.888/
    Make : Apple
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Codec ID : avc1
    Source duration : 43s 402ms
    Bit rate : 17.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Rotation : 90°
    Frame rate mode : Variable
    Frame rate : 29.469 fps
    Minimum frame rate : 24.000 fps
    Maximum frame rate : 30.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.279
    Stream size : 88.1 MiB
    Source stream size : 88.1 MiB
    Title : Core Media Video
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Source : Roll 1\IMG_2008.MOV
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Source duration : 43s 421ms
    Bit rate mode : Constant
    Bit rate : 64.0 Kbps
    Channel(s) : 1 channel
    Channel positions : Front: C
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 337 KiB
    Source stream size : 337 KiB
    Title : Core Media Audio
  4. It's just standard h.264 video, aac audio - you can edit it with any NLE e.g. vegas pro, premiere pro
    Free editors like avidemux should be able to open it as well
    You can play it with normal media players e.g. VLC, MPCHC, SMplayer
    You can convert it with something like TEncoder, WinFF, avidemux
    It's variable frame rate video (VFR)- so editing it may cause sections to go slightly out of sync. You would have to convert it to CFR before editing in most applications
  5. When i double click on the video Vlc opens and does not play anything whereas Media player says that : Windows Media Player can not play the file. It is possible that the reader does not take care of the file type or the codec used to compress it.
    Oct 2005
    666th portal
    you could try installing apple quicktime or quicktime alternative
  7. Looking at it a bit closer
    This can't be the real video, it's too small. Either it's damaged, or something (lots) missing
    Can you confirm the size of the video ?
  8. The video was sent to me, the other one can watch it but when i recieve it it's dead.
  9. It's probably damaged or corrupted. Can the other person send it to you again ?
  10. He did quite some times. But nothing seems to work.
  11. Thank you the videos were damaged every time he was sending them so i told him to send from the first device, so they worked.
