So I bought the new BDBOX of the Fate/Zero anime series which cost me a SHITLOAD of money (from here: http://www.fatezerousa.com/product-br-disc-box-2.php). I already had the DVDs but I wanted to get the 1080p versions so I could edit them since this anime's animation is so freaking amazing.
I had My BDs ripped by a friend and got a bunch of .mkv files which I'm okay with. I used MkvToMp4 to convert them to .mp4 and edit them in Vegas Movie Studio HD Platinum 11.0 ... I insert the files in the trimmer after the conversion but it's all weirdish. Some scenes just play over and over, some others just don't at all, flashes etc. are removed! I get them on the timeline and RAM preview but they are just uneditable.
The converted mp4s are all fine though when I play them in any players ! Can anyone help please?
These are the project properties set in Vegas Movie Studio HD Platinum 11.0 when I try to edit the files :
HD 1080-60i (1920x1080; 29,970 fps)
Here is some info on the mp4 files from mediainfo:
General
Complete name : C:\Users\lenovo\Desktop\Editing\New BD Orders\Fate Zero\BDBOX II RIP\Fate Zero NCOP2.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 65.8 MiB
Duration : 1mn 33s
Overall bit rate : 5 926 Kbps
Movie name : Fate Zero NCOP2
Encoded date : UTC 2012-12-27 16:09:27
Tagged date : UTC 2012-12-27 16:09:28
Writing application : MkvToMp4 [www.mkvtomp4.ru] version 0.222
hdvd : 2
stik : 0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Duration : 1mn 33s
Bit rate : 5 729 Kbps
Maximum bit rate : 18.4 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.115
Stream size : 63.5 MiB (97%)
Writing library : x264 core 125 r2208 d9d2288
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=230 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=15 / qpmax=23 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1mn 33s
Bit rate mode : Variable
Bit rate : 192 Kbps
Maximum bit rate : 218 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 2.16 MiB (3%)
Language : English
Encoded date : UTC 2012-12-27 16:09:28
well your project properties are wrong. they should be set to 1920x1080 23.976 progressive.
Did that. Same problem!
I rendered the file and I'm uploading it here right now, watch it please. Note: wherever its lagging, there should flashes there.
Watch THIS video to see how it SHOULD be: watch from 0:18 to 0:50 ! http://www.youtube.com/watch?v=PVMqG5n6oo8 -
I tried the files in After Effects and they work just fine in there. I can't understand what the problem is with Vegas Movie!
Problem solved.
I did what I usually do in hard times, which is using Handbrake.
Converted the .mkv files with Handbrake and everything works like a charm.
Thank you guys very much for replying, reading my messages and attempting to find a solution.
Wishing you a great New Year's celebration and happiness,health and prosperity!
Blu Ray 720p vs 1080p
By zork152 in forum Newbie / General discussionsReplies: 6Last Post: 11th Jan 2010, 11:32 -
Need help fitting a compressed Blu ray film 1080p into a DL DVD
By jones24 in forum Authoring (Blu-ray)Replies: 9Last Post: 26th Sep 2009, 21:21 -
Blu-ray (1080p) menu template .PSD? Anyone got one?
By Asterra in forum Authoring (Blu-ray)Replies: 4Last Post: 18th Jul 2009, 16:50 -
DV AVI to 1080p? Thence Blu Ray?
By Maxwellbest in forum Video ConversionReplies: 4Last Post: 16th Jan 2009, 15:45 -
x264 1080p blu-ray files
By eric11111 in forum Authoring (Blu-ray)Replies: 6Last Post: 7th Dec 2008, 09:48
