  1. I'd like to download the commercial that pops up here: http://watchdisneyjunior.go.com/ I have used another user's posted advice to try to use the m3u8 link to download, but, alas, I can't get the FFMpeg commands to run on my Windows computer (tried adding its path to environment variables and my registry to get it installed, to no avail). I then tried downloading the individual TS files from the M3U8 link I thiiink is right (http://content.uplynk.com/ext/21885d134fa441488df8e1d7acee8c66/WatchDJR.m3u8)...but when I download any TS file ends up being 0 KB. Help, please? I'm obviously clueless about all of this. Thanks in advance! Edit: The TS files are *not* 0 KB in size...just no program seems to be able to join them. HandBrake says, "Your Source may be copy protected, badly mastered, or in a format which HandBrake does not support."
  2. This is driving me crazy! The TS files have sizes, but there doesn't seem to be *anything* in them (I don't come up with codecs, a file format, or anything else when I look them up in MediaInfo).
    Oct 2005
    666th portal
    use a screen recorder?
  4. Thanks for your reply! Screen recording, I thought, should be my last resort...what program do you recommend (can it record without a mic?)? If it is possible for someone to do this without recording, I think I would prefer it...would even be willing to pay someone to help with this specific task!
