Greetings ....
I am considering using FREEDOS to run some old programs. I understand that a bootable FREEDOS CD can run on my current desktop, which incidentally uses Win XP-32 Home-SP3, has an AMD Athlon 64x2 Dual Core 2.50-ghz processor w/3.25-gb ram, plus a 465-GB hard drive (about 80% free space, at present).
To hold and execute all my old programs, I'm thinking about installing a 2nd hard drive of 250-gb in size, which I could re-partition into two equal halves of 125-gb or four equal quarters of 62.50-gb each. Unless someone can say otherwise, I'm under the assumption that drives/partitions above 128-gb are an issue with FREEDOS.
I am aware of some Seagate 250-gb drives, one of which is available with good reviews at Tiger Direct. That particular drive is a 2.50-inch type, but I believe I'm correct in assuming that a 3.50-inch adapter would allow me to install such a drive in my current desktop.
Please let me know if all this sounds right.
Thanx-A-Lot, a belated Merry Christmas and Very Happy New Year
Frank-0-Video
THE Ultimate TV Tuner Device - Picks up every broadcast-cable-satellite transmission since 1928! -
That sound good.
I'm using DOSBox with the same results.
http://www.dosbox.comTop 10 ways to amuse a geek:
1. Make a list of the top 10 ways to amuse a geek.
10. Use binary. -
I tried that once on my homebuild AMD quad/3.0 GHz, EVGA video card, 4gig RAM. I dedicated a 250gig SATA hard drive (installed in the same box) for running older games. Formatted FAT32 with DOS. The problem is that the games would not run with the newer technology hardware. I would just get error messages complaining about conflicts with video card, etc. I finally built a computer using old hardware and the games run like crazy. Another thing you may find, some games that you may get to load will react like they are in speeded up motion (like those old, antique silent films were wayyyy back). There is a utility that will slow the speed down to normal, I forget the name now.FREEDOS to run some old programs
Anyway, that is my experience. -
Just install Virtualbox, no partitioning required, it runs inside windows and it simulates standard hardware.
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
How to set the HD's for editing ?
By Dash1 in forum Newbie / General discussionsReplies: 6Last Post: 16th Sep 2009, 07:54 -
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 16:39 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 16:59 -
2 PC's, 1 Set of speakers
By SIRCOOKS in forum ComputerReplies: 15Last Post: 12th Feb 2008, 17:56
