  1. Any advice on how to debug DeVeDe Error: "Conversion failed. It seems a bug of Mencoder" on Centos 6 Linux?
  2. Can you help me pinpoint the problem from the information in this log file, obtained by running DeVeDe from the command line:
    DeVeDe 3.21.0
    Locale: en_US.UTF-8
    Using package-installed files
    /home/user1/
    Cores: 4
    Entro en fonts
    Salgo de fonts
    /home/user1/
    Temp Directory is:  /var/tmp
    home load:  /home/user1/.devede
    linea:  video_format:ntsc
    linea:  temp_folder:/var/tmp/
    linea:  multicore:4
    linea:  final_folder:/media/usb_disk/tmp
    linea:  sub_language:EN (ENGLISH)
    linea:  sub_codepage:ISO-8859-1
    linea:  AC3_fix:1
    linea:  erase_tmp_files:1
    linea:  use_ffmpeg:1
    linea:
    Creating window /usr/share/devede/wdisk_type.ui
    Creating window /usr/share/devede/wmain.ui
    /usr/share/devede/devede_other.py:716: GtkWarning: Unknown property: GtkMenu.ubuntu-local
      tree.add_from_file(filename)
    Launching program:  mplayer -loop 1 -identify -ao null -vo null -frames 0 /usr/share/devede/silence.ogg
    elemento:  /usr/bin
    Longitud sonido: 38
    PAL: False
    elemento:  /usr/bin
    Longitud sonido: 38
    Calculating size for disk :dvd
    drop
    Dragged files: ['/media/usb_disk/movie/test.avi']
    Launching program:  mplayer -loop 1 -identify -ao null -vo null -frames 0 /media/usb_disk/movie/test.avi
    elemento:  /usr/bin
    Launching program:  mplayer -loop 1 -identify -ao null -vo null -frames 1 /media/usb_disk/movie/test.avi
    elemento:  /usr/bin
    [mpeg4 @ 0xc52a60]Invalid and inefficient vfw-avi packed B frames detected
    True
    0
    Threads: 4
    Creating window /usr/share/devede/wprogress.ui
    Creating window /usr/share/devede/wfolder_dialog.ui
    Entro en RUN
    Salgo de RUN
    Creating window /usr/share/devede/wfolder_exists.ui
    Path para borrar: /media/usb_disk/tmp/movie/movie
    Checking /media/usb_disk/tmp/movie/
    Free space in /media/usb_disk/tmp/movie/: 11653642
    estatus  posix.statvfs_result(f_bsize=4096, f_frsize=4096, f_blocks=39072080, f_bfree=2994871, f_bavail=2994871, f_files=12012252, f_ffree=11985913, f_favail=11985913, f_flag=4102, f_namemax=255)
    Free: 11653642
    Needed: 3136439.0
    /media/usb_disk/tmp/movie/movie.cue not found
    /media/usb_disk/tmp/movie/movie.bin not found
    /media/usb_disk/tmp/movie/movie/ not found
    /media/usb_disk/tmp/movie/movie.iso not found
    delete menu temp
    delete menu
    Deleting movie_??_??.mpg
    Deleting movie.log
    /media/usb_disk/tmp/movie/movie.log not found
    /media/usb_disk/tmp/movie/movie.xml not found
    Borro principal
    Menu PAL: False
    Elementos por menu: 11
    Menu1 0 0
    Uso /usr/share/devede/backgrounds/default_bg.png
    0.35
    Paint_bg 0 title text:
    0.35
    Paint_bg 1 title text:
    0.35
    Paint_bg 3 title text:
    Creating menus
    Lanzo ['ffmpeg', '-loop_input', '-f', 'image2', '-t', '39', '-i', '/media/usb_disk/tmp/movie/movie_menu0_bg.png', '-i', '/usr/share/devede/silence.ogg', '-y', '-target', 'ntsc-dvd', '-s', '720x480', '-g', '12', '-ac', '2', '-trellis', '1', '-mbd', '2', '-b', '1000000', '-ab', '128000', '-aspect', '4:3', '/media/usb_disk/tmp/movie/movie_menu_0.mpg']
    Launching program:  ffmpeg -loop_input -f image2 -t 39 -i /media/usb_disk/tmp/movie/movie_menu0_bg.png -i /usr/share/devede/silence.ogg -y -target ntsc-dvd -s 720x480 -g 12 -ac 2 -trellis 1 -mbd 2 -b 1000000 -ab 128000 -aspect 4:3 /media/usb_disk/tmp/movie/movie_menu_0.mpg
    elemento:  /usr/bin
    FFmpeg version 0.6.5, Copyright (c) 2000-2010 the FFmpeg developers
      built on Jan 29 2012 17:52:15 with gcc 4.4.5 20110214 (Red Hat 4.4.5-6)
      configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandi r=/usr/share/man --incdir=/usr/include --disable-avisynth --extra-cflags='-O2 -g  -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp- buffer-size=4 -m64 -mtune=generic -fPIC' --enable-avfilter --enable-avfilter-lav f --enable-libdc1394 --enable-libdirac --enable-libfaac --enable-libfaad --enabl e-libfaadbin --enable-libgsm --enable-libmp3lame --enable-libopencore-amrnb --en able-libopencore-amrwb --enable-librtmp --enable-libschroedinger --enable-libspe ex --enable-libtheora --enable-libx264 --enable-gpl --enable-nonfree --enable-po stproc --enable-pthreads --enable-shared --enable-swscale --enable-vdpau --enabl e-version3 --enable-x11grab
      libavutil     50.15. 1 / 50.15. 1
      libavcodec    52.72. 2 / 52.72. 2
      libavformat   52.64. 2 / 52.64. 2
      libavdevice   52. 2. 0 / 52. 2. 0
      libavfilter    1.19. 0 /  1.19. 0
      libswscale     0.11. 0 /  0.11. 0
      libpostproc   51. 2. 0 / 51. 2. 0
    Input #0, image2, from '/media/usb_disk/tmp/movie/movie_menu0_bg.png':
      Duration: 00:00:00.04, start: 0.000000, bitrate: N/A
        Stream #0.0: Video: png, bgra, 720x480, 25 fps, 25 tbr, 25 tbn, 25 tbc
    Input #1, ogg, from '/usr/share/devede/silence.ogg':
      Duration: 00:00:38.05, start: 0.000000, bitrate: 1 kb/s
        Stream #1.0: Audio: vorbis, 48000 Hz, stereo, s16, 64 kb/s
        Metadata:
          ENCODER         : VLC media player
    Output #0, dvd, to '/media/usb_disk/tmp/movie/movie_menu_0.mpg':
      Metadata:
        encoder         : Lavf52.64.2
        Stream #0.0: Video: mpeg2video (hq), yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=2 -31, 1000 kb/s, 90k tbn, 29.97 tbc
        Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 128 kb/s
        Metadata:
    Stream mapping:
      Stream #0.0 -> #0.0
      Stream #1.0 -> #0.1
    Press [q] to stop encoding
    frame=   41 fps=  0 q=2.0 size=     114kB time=1.31 bitrate= 711.8kbits/s dup=6  drop=0    frame=   82 fps= 79 q=2.0 size=     220kB time=2.66 bitrate= 678.6kbi ts/s dup=13 drop=0    frame=  122 fps= 79 q=2.0 size=     356kB time=4.03 bitra te= 723.3kbits/s dup=19 drop=0    frame=  162 fps= 79 q=2.0 size=     460kB tim e=5.34 bitrate= 705.1kbits/s dup=26 drop=0    frame=  203 fps= 79 q=2.0 size=      564kB time=6.69 bitrate= 690.8kbits/s dup=33 drop=0    frame=  243 fps= 80 q =2.0 size=     698kB time=8.06 bitrate= 709.1kbits/s dup=39 drop=0    frame=  2 84 fps= 80 q=2.0 size=     804kB time=9.44 bitrate= 697.7kbits/s dup=46 drop=0     frame=  325 fps= 80 q=1.6 size=     910kB time=10.78 bitrate= 691.3kbits/s du p=53 drop=0    frame=  366 fps= 80 q=2.0 size=    1042kB time=12.13 bitrate= 70 3.8kbits/s dup=60 drop=0    frame=  406 fps= 80 q=2.0 size=    1148kB time=13.5 0 bitrate= 696.4kbits/s dup=66 drop=0    frame=  447 fps= 80 q=2.0 size=    128 4kB time=14.88 bitrate= 706.9kbits/s dup=73 drop=0    frame=  488 fps= 80 q=2.0  size=    1388kB time=16.22 bitrate= 700.8kbits/s dup=80 drop=0    frame=  529  fps= 80 q=1.6 size=    1492kB time=17.57 bitrate= 695.7kbits/s dup=87 drop=0     frame=  569 fps= 80 q=2.0 size=    1626kB time=18.94 bitrate= 703.1kbits/s dup= 93 drop=0    frame=  610 fps= 80 q=2.0 size=    1732kB time=20.29 bitrate= 699. 4kbits/s dup=100 drop=0    frame=  650 fps= 80 q=2.0 size=    1866kB time=21.63  bitrate= 706.7kbits/s dup=107 drop=0    frame=  691 fps= 80 q=2.0 size=    197 2kB time=22.98 bitrate= 703.1kbits/s dup=114 drop=0    frame=  731 fps= 80 q=2. 0 size=    2074kB time=24.35 bitrate= 697.7kbits/s dup=120 drop=0    frame=  77 2 fps= 80 q=2.0 size=    2210kB time=25.70 bitrate= 704.6kbits/s dup=127 drop=0     frame=  812 fps= 80 q=2.0 size=    2316kB time=27.01 bitrate= 702.5kbits/s d up=134 drop=0    frame=  852 fps= 80 q=2.0 size=    2418kB time=28.38 bitrate=  697.9kbits/s dup=140 drop=0    frame=  893 fps= 80 q=2.0 size=    2554kB time=2 9.76 bitrate= 703.0kbits/s dup=147 drop=0    frame=  934 fps= 80 q=2.0 size=     2660kB time=31.10 bitrate= 700.6kbits/s dup=154 drop=0    frame=  973 fps= 80  q=1.6 size=    2766kB time=32.42 bitrate= 699.0kbits/s dup=160 drop=0    frame=  1014 fps= 80 q=2.0 size=    2900kB time=33.79 bitrate= 703.0kbits/s dup=167 dro p=0    frame= 1055 fps= 80 q=2.0 size=    3002kB time=35.14 bitrate= 699.9kbits /s dup=174 drop=0    frame= 1096 fps= 80 q=2.0 size=    3138kB time=36.51 bitra te= 704.1kbits/s dup=181 drop=0    frame= 1135 fps= 80 q=2.0 size=    3244kB ti  frame= 1168 fps= 80 q=2.0 Lsize=    3346kB time=38.08 bitrate= 719.8kbits/s dup=193 drop=0
    video:2349kB audio:595kB global headers:0kB muxing overhead 13.672651%
    Launch: spumux "/media/usb_disk/tmp/movie/movie_menu_0.xml"
    Launching shell program: spumux "/media/usb_disk/tmp/movie/movie_menu_0.xml" < "/media/usb_disk/tmp/movie/movie_menu_0.mpg" > "/media/usb_disk/tmp/movie/movie_menu2_0.mpg"
    delete menu temp
    Segundos 0
    Addbars True resx_o 720 resy_o 288
    resx_i 720 resy_i 340
    Launching program:  ffmpeg -i /media/usb_disk/movie/test.avi -vf scale=720:340,fifo,pad=720:480:0:70:0x000000 -y -target ntsc-dvd -sn -g 12 -ac 2 -s 720x480 -threads 4 -trellis 1 -mbd 2 -b 5001000 -ab 224000 -aspect 16:9 /media/usb_disk/tmp/movie/movie_01_01.mpg
    elemento:  /usr/bin
      configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandir=/usr/share/man --incdir=/usr/include --disable-avisynth --extra-cflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -fPIC' --enable-avfilter --enable-avfilter-lavf --enable-libdc1394 --enable-libdirac --enable-libfaac --enable-libfaad --enable-libfaadbin --enable-libgsm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libx264 --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-shared --enable-swscale --enable-vdpau --enable-version3 --enable-x11grab
    [mpeg4 @ 0x24af980]Invalid and inefficient vfw-avi packed B frames detected
    Input #0, avi, from '/media/usb_disk/movie/test.avi':
      Metadata:
        ISFT            : VirtualDubMod 1.5.10.2 (build 2540/release)
      Duration: 01:19:54.88, start: 0.000000, bitrate: 2967 kb/s
        Stream #0.0: Video: mpeg4, yuv420p, 720x288 [PAR 1:1 DAR 5:2], 25 tbr, 25 tbn, 25 tbc
        Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    Unrecognized option 'vf'
    Creating window /usr/share/devede/werror_dialog.ui
      ===>Error Conversion failed. It seems a bug of Mencoder.<===
    Creating window /usr/share/devede/wcancel_dialog.ui
    Saving configuration
    Exiting
    Have a nice day
  3. I don't think it's the particular AVI, because EVERY AVI that I send to DeVeDe fails with the same error.
    Does this log file pinpoint where the problem may lie?
    DeVeDe 3.21.0
    Locale: en_US.UTF-8
    /home/user1/
    Cores: 4
    Entro en fonts
    Salgo de fonts
    /home/user1/
    linea:  multicore:4
    linea:  AC3_fix:1
    linea:  use_ffmpeg:1
    linea:
    elemento:  /usr/bin
    Longitud sonido: 38
    PAL: False
    elemento:  /usr/bin
    Longitud sonido: 38
    drop
    Dragged files: ['/media/usb_disk/movie/film.avi']
    Launching program:  mplayer -loop 1 -identify -ao null -vo null -frames 0 /media/usb_disk/movie/film.avi
    elemento:  /usr/bin
    Launching program:  mplayer -loop 1 -identify -ao null -vo null -frames 1 /media/usb_disk/movie/film.avi
    elemento:  /usr/bin
    True
    0
    4054
    Threads: 4
    Entro en RUN
    Salgo de RUN
    Free space in /media/usb_disk/tmp/movie/: 9964398
    estatus  posix.statvfs_result(f_bsize=4096, f_frsize=4096, f_blocks=39072080, f_bfree=2560752, f_bavail=2560752, f_files=10275776, f_ffree=10249436, f_favail=10249436, f_flag=4102, f_namemax=255)
    Free: 9964398
    Needed: 3863579.0
    delete menu temp
    delete menu
    Deleting movie.log
    Borro principal
    Menu PAL: False
    Menu1 0 0
    0.35
    0.35
    0.35
    Creating menus
    elemento:  /usr/bin
        Metadata:
      Metadata:
        Metadata:
    Stream mapping:
      Stream #0.0 -> #0.0
      Stream #1.0 -> #0.1
    frame=   40 fps=  0 q=2.0 size=     114kB time=1.25 bitrate= 748.3kbits/s dup=6  drop=0    frame=   79 fps= 76 q=2.0 size=     220kB time=2.59 bitrate= 695.3kbi ts/s dup=12 drop=0    frame=  119 fps= 77 q=2.0 size=     322kB time=3.87 bitra te= 681.3kbits/s dup=19 drop=0    frame=  158 fps= 78 q=2.0 size=     458kB tim e=5.22 bitrate= 719.3kbits/s dup=25 drop=0    frame=  198 fps= 78 q=2.0 size=      564kB time=6.56 bitrate= 704.3kbits/s dup=32 drop=0    frame=  239 fps= 78 q =2.0 size=     666kB time=7.90 bitrate= 690.3kbits/s dup=39 drop=0    frame=  2 79 fps= 78 q=2.0 size=     802kB time=9.25 bitrate= 710.4kbits/s dup=45 drop=0     frame=  319 fps= 78 q=2.0 size=     908kB time=10.59 bitrate= 702.3kbits/s du p=52 drop=0    frame=  360 fps= 78 q=2.0 size=    1010kB time=11.94 bitrate= 69 3.2kbits/s dup=59 drop=0    frame=  400 fps= 78 q=2.0 size=    1146kB time=13.2 8 bitrate= 706.9kbits/s dup=65 drop=0    frame=  440 fps= 78 q=2.0 size=    125 0kB time=14.62 bitrate= 700.2kbits/s dup=72 drop=0    frame=  480 fps= 79 q=2.0  size=    1354kB time=15.94 bitrate= 696.0kbits/s dup=79 drop=0    frame=  519  fps= 79 q=2.0 size=    1490kB time=17.28 bitrate= 706.4kbits/s dup=85 drop=0     frame=  559 fps= 79 q=2.0 size=    1594kB time=18.56 bitrate= 703.6kbits/s dup= 92 drop=0    frame=  598 fps= 79 q=2.0 size=    1698kB time=19.90 bitrate= 698. 9kbits/s dup=98 drop=0    frame=  638 fps= 79 q=2.0 size=    1832kB time=21.25  bitrate= 706.3kbits/s dup=105 drop=0    frame=  679 fps= 79 q=2.0 size=    1938 kB time=22.56 bitrate= 703.7kbits/s dup=112 drop=0    frame=  718 fps= 79 q=2.0  size=    2040kB time=23.90 bitrate= 699.1kbits/s dup=118 drop=0    frame=  758  fps= 79 q=2.0 size=    2148kB time=25.22 bitrate= 697.8kbits/s dup=125 drop=0     frame=  798 fps= 79 q=2.0 size=    2282kB time=26.56 bitrate= 703.8kbits/s du p=131 drop=0    frame=  838 fps= 79 q=2.0 size=    2384kB time=27.90 bitrate= 6 99.9kbits/s dup=138 drop=0    frame=  878 fps= 79 q=2.0 size=    2492kB time=29 .22 bitrate= 698.7kbits/s dup=145 drop=0    frame=  916 fps= 78 q=2.0 size=     2624kB time=30.53 bitrate= 704.1kbits/s dup=151 drop=0    frame=  955 fps= 78 q =2.0 size=    2728kB time=31.81 bitrate= 702.6kbits/s dup=157 drop=0    frame=   993 fps= 78 q=2.0 size=    2832kB time=33.06 bitrate= 701.8kbits/s dup=164 drop =0    frame= 1032 fps= 78 q=2.0 size=    2934kB time=34.37 bitrate= 699.4kbits/ s dup=170 drop=0    frame= 1072 fps= 78 q=2.0 size=    3070kB time=35.71 bitrat e= 704.2kbits/s dup=177 drop=0    frame= 1112 fps= 78 q=2.0 size=    3174kB tim e=37.06 bitrate= 701.7kbits/s dup=183 drop=0    frame= 1153 fps= 78 q=1.6 size=  frame= 1168 fps= 78 q=2.0 Lsize=    3346kB time=38.08 bitrate= 719.8kbits/s dup=193 drop=0
    delete menu temp
    Segundos 0
    Addbars True resx_o 852 resy_o 480
    resx_i 718 resy_i 480
    Launching program:  ffmpeg -i /media/usb_disk/movie/film.avi -vf scale=718:480,fifo,pad=720:480:2:0:0x000000 -y -target ntsc-dvd -sn -g 12 -ac 2 -s 720x480 -threads 4 -trellis 1 -mbd 2 -b 4054000 -ab 224000 -aspect 16:9 /media/usb_disk/tmp/movie/movie_01_01.mpg
    elemento:  /usr/bin
    Seems stream 0 codec frame rate differs from container frame rate: 24000.00 (24000/1) -> 23.98 (24000/1001)
    Input #0, avi, from '/media/usb_disk/movie/film.avi':
      Metadata:
        ISFT            : Lavf51.12.1
      Duration: 02:00:15.87, start: 0.000000, bitrate: 1971 kb/s
        Stream #0.0: Video: mpeg4, yuv420p, 852x480 [PAR 1:1 DAR 71:40], 23.98 fps, 23.98 tbr, 23.98 tbn, 24k tbc
        Stream #0.1: Audio: mp3, 44100 Hz, 2 channels, s16, 320 kb/s
    /home/user1/
    Exiting
    Have a nice day
  4. I tried uninstalling and reinstalling the software - but the error remained:
    $ sudo yum erase dvdauthor vcdimager mencoder devede libvcdinfo mplayer ffmpeg
    $ sudo yum --enablerepo=rpmforge --enablerepo=linuxtech-testing install vcdimager mencoder dvdauthor devede mplayer ffmpeg
    REPORTED:
     Package            Arch   Version                      Repository         Size
    Installing:
     devede             noarch 3.21.0-1.el6                 linuxtech-testing 2.0 M
     dvdauthor          x86_64 0.6.11-1.2.el6.rf            rpmforge          152 k
     ffmpeg             x86_64 0.6.5-1.el6.rf               rpmforge          2.7 M
     mencoder           x86_64 1.0-0.47.svn20100703.el6.rf  rpmforge          3.5 M
     mplayer            x86_64 1.0-0.47.svn20100703.el6.rf  rpmforge          4.0 M
     vcdimager          x86_64 0.7.23-5.el6.rf              rpmforge          436 k
    Installing for dependencies:
     ffmpeg-libpostproc x86_64 0.6.5-1.el6.rf               rpmforge           24 k
    Transaction Summary
    Install       7 Package(s)
  5. Member bat999's Avatar
    Feb 2008
    Hi
    These are the clues:-
    It looks like the problem is with FFmpeg, not MEncoder.
    It doesn't recognize the '-vf' option. Maybe it's because your version of FFmpeg is too old.
    When I use the same FFmpeg command with a test file it runs OK.
    @ubuntu:~$ ffmpeg -i filename.avi -vf scale=720:340,fifo,pad=720:480:0:70:0x000000 -y -target ntsc-dvd -sn -g 12 -ac 2 -s 720x480 -threads 4 -trellis 1 -mbd 2 -b 5001000 -ab 224000 -aspect 16:9 filename.mpg
    ffmpeg version git-2012-12-18-9700a7a Copyright (c) 2000-2012 the FFmpeg developers
    built on Dec 18 2012 22:46:47 with gcc 4.5.2 (Ubuntu/Linaro 4.5.2-8ubuntu4)
    configuration: --enable-gpl --enable-libaacplus --enable-libfaac --enable-libfdk-aac --enable-libilbc --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopus --enable-librtmp --enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid --enable-nonfree --enable-version3 --enable-x11grab
    libavutil 52. 12.100 / 52. 12.100
    libavcodec 54. 80.100 / 54. 80.100
    libavformat 54. 49.102 / 54. 49.102
    libavdevice 54. 3.102 / 54. 3.102
    libavfilter 3. 28.100 / 3. 28.100
    libswscale 2. 1.103 / 2. 1.103
    libswresample 0. 17.102 / 0. 17.102
    libpostproc 52. 2.100 / 52. 2.100
    Input #0, avi, from 'filename.avi':
    Metadata:
    encoder : Lavf54.49.102
    Duration: 00:01:33.13, start: 0.000000, bitrate: 1148 kb/s
    Stream #0:0: Video: vp6f (VP6F / 0x46365056), yuv420p, 1024x576, 29.97 tbr, 1k tbn, 1k tbc
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, mono, s16p, 64 kb/s
    Please use -b:a or -b:v, -b is ambiguous
    Output #0, dvd, to 'filename.mpg':
    Metadata:
    Stream #0:0: Video: mpeg2video (hq), yuv420p, 720x480 [SAR 32:27 DAR 16:9], q=2-31, 5001 kb/s, 90k tbn, 29.97 tbc
    Stream #0:1: Audio: ac3, 48000 Hz, stereo, fltp, 224 kb/s
    Stream mapping:
    Stream #0:0 -> #0:0 (vp6f -> mpeg2video)
    Stream #0:1 -> #0:1 (mp3 -> ac3)
    Press [q] to stop, [?] for help
    frame= 2791 fps=9.0 q=2.0 Lsize= 43676kB time=00:01:33.14 bitrate=3841.2kbits/s
    video:39889kB audio:2547kB subtitle:0 global headers:0kB muxing overhead 2.921323%
  6. Originally Posted by bat999 View Post
    Success at last!
    Thank you very much for helping me as I realize this is a difficult task from where you sit.
    Taking your advice (that DeVeDe was making a bad call to a sub program), I uninstalled DeVeDe & reinstalled from a different repository.
    When I deleted the Linuxtech DeVeDe & replaced it with a Fedora DeVeDe found using Pbone, everything all of a sudden just worked!
    Hooray!
    Here is the resultant log file using the exact same video, PC, and hard drive that failed in the tests above!
    $ /usr/bin/devede
    DeVeDe 3.16.9
    Locale: en_US.UTF-8
    /home/user1/
    Entro en fonts
    Salgo de fonts
    /home/user1/
    elemento:  /usr/bin
    Longitud sonido: 38
    Cores: 4
    elemento:  /usr/bin
    Longitud sonido: 38
    Creating window /usr/share/devede/aboutdialog1.ui
    elemento:  /usr/bin
    elemento:  /usr/bin
    True
    0
    4237
    Threads: 1
    Path para borrar: /home/user1/rpmbuild/RPMS/noarch/movie/movie
    Checking /home/user1/rpmbuild/RPMS/noarch/movie/
    Free space in /home/user1/rpmbuild/RPMS/noarch/movie/: 6661804
    estatus  posix.statvfs_result(f_bsize=4096, f_frsize=4096, f_blocks=21049476, f_bfree=2781278, f_bavail=1712018, f_files=5349376, f_ffree=4296847, f_favail=4296847, f_flag=4096, f_namemax=255)
    Free: 6661804
    Needed: 3863565.0
    Threads: 1
    Path para borrar: /media/usb_disk/movie/movie/movie
    Checking /media/usb_disk/movie/movie/
    Free space in /media/usb_disk/movie/movie/: 9964398
    estatus  posix.statvfs_result(f_bsize=4096, f_frsize=4096, f_blocks=39072080, f_bfree=2560752, f_bavail=2560752, f_files=10275776, f_ffree=10249434, f_favail=10249434, f_flag=4102, f_namemax=255)
    Free: 9964398
    Needed: 3863565.0
    /media/usb_disk/movie/movie/movie.cue not found
    /media/usb_disk/movie/movie/movie.bin not found
    /media/usb_disk/movie/movie/movie/ not found
    /media/usb_disk/movie/movie/movie.iso not found
    delete menu temp
    delete menu
    Deleting movie.log
    /media/usb_disk/movie/movie/movie.log not found
    /media/usb_disk/movie/movie/movie.xml not found
    Borro principal
    Menu PAL: True
    Menu1 0 0
    0.325
    0.325
    0.325
    Creating menus
    Lanzo ['mencoder', '-srate', '48000', '-af', 'lavcresample=48000', '-oac', 'lavc', '-ovc', 'lavc', '-of', 'mpeg', '-mpegopts', 'format=dvd:tsaf', '-ofps', '25', '-vf', 'scale=720:576,harddup', '-lavcopts', 'vcodec=mpeg2video:sc_threshold=1000000000:cgop:trell:mbd=2:vstrict=0:vrc_maxrate=7000:vrc_buf_size=1835:vbitrate=1000:keyint=12:acodec=ac3:abitrate=128:aspect=4/3', '-o', '/media/usb_disk/movie/movie/movie_menu_0.mpg', '-audiofile', '/usr/share/devede/silence.ogg', '-mf', 'type=png:fps=1/38', 'mf:///media/usb_disk/movie/movie/movie_menu0_bg.png']
    Launching program:  mencoder -srate 48000 -af lavcresample=48000 -oac lavc -ovc lavc -of mpeg -mpegopts format=dvd:tsaf -ofps 25 -vf scale=720:576,harddup -lavcopts vcodec=mpeg2video:sc_threshold=1000000000:cgop:trell:mbd=2:vstrict=0:vrc_maxrate=7000:vrc_buf_size=1835:vbitrate=1000:keyint=12:acodec=ac3:abitrate=128:aspect=4/3 -o /media/usb_disk/movie/movie/movie_menu_0.mpg -audiofile /usr/share/devede/silence.ogg -mf type=png:fps=1/38 mf:///media/usb_disk/movie/movie/movie_menu0_bg.png
    elemento:  /usr/bin
    [ac3 @ 0x2f4cab0] No channel layout specified. The encoder will guess the layout MEncoder SVN-r31628-4.4.5 (C) 2000-2010 MPlayer Team
    success: format: 16  data: 0x0 - 0x0
    MF file format detected.
    [mf] search expr: /media/usb_disk/movie/movie/movie_menu0_bg.png*
    [mf] number of files: 1 (8)
    VIDEO:  [MPNG]  0x0  24bpp  0.026 fps    0.0 kbps ( 0.0 kbyte/s)
    libavformat file format detected.
    [lavf] stream 0: audio (vorbis), -aid 0
    [V] filefmt:65536  fourcc:0x474E504D  size:0x0  fps:0.026  ftime:=38.0000
    Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
    AUDIO: 48000 Hz, 2 ch, s16le, 64.0 kbit/4.17% (ratio: 8000->192000)
    Selected audio codec: [ffvorbis] afm: ffmpeg (FFmpeg Vorbis)
    PACKET SIZE: 2048 bytes, deltascr: 43885
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [harddup]
    Opening video filter: [scale w=720 h=576]
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    Selected video codec: [ffpng] vfm: ffmpeg (FFmpeg PNG)
    Movie-Aspect is undefined - no prescaling applied.
    videocodec: libavcodec (720x576 fourcc=3267706d [mpg2])
    [VE_LAVC] High quality encoding selected (non-realtime)!
    Writing header...
    INITV: 0.200, 0.160, fps: 25.000
    Pos:  38.0s      1f ( 0%)  0.17fps Trem:   0min   0mb  A-V:0.000 [482:0]
    Flushing video frames.
    Writing index...
    , but it might be incorrect.
    Launch: spumux "/media/usb_disk/movie/movie/movie_menu_0.xml"
    Launching shell program: spumux "/media/usb_disk/movie/movie/movie_menu_0.xml" < "/media/usb_disk/movie/movie/movie_menu_0.mpg" > "/media/usb_disk/movie/movie/movie_menu2_0.mpg"
    delete menu temp
    Segundos 0
    Addbars False resx_o 852 resy_o 480
    resx_i 852 resy_i 480
    Launching program:  mencoder -srate 48000 -speed 25025:24000 -af lavcresample=48000 -noautosub -oac lavc -aid 1 -ovc lavc -of mpeg -mpegopts format=dvd:tsaf -ofps 25 -vf scale=720:576,harddup -lavcopts vcodec=mpeg2video:trell:mbd=2:sc_threshold=1000000000:cgop:vstrict=0:vrc_maxrate=8474:vrc_buf_size=1835:vbitrate=4237:keyint=12:acodec=ac3:abitrate=224:aspect=16/9 -o /media/usb_disk/movie/movie/movie_01_01.mpg /media/usb_disk/movie/film.avi
    elemento:  /usr/bin
    [ac3 @ 0x2b1b930] No channel layout specified. The encoder will guess the layout, but it might be incorrect.
    Limiting audio preload to 0.4s.
    Launching program:  dvdauthor -x /media/usb_disk/movie/movie/movie.xml
    elemento:  /usr/bin
    DVDAuthor::dvdauthor, version 0.6.11.
    Build options: gnugetopt magick iconv freetype
    Send bugs to <dvdauthor-users@lists.sourceforge.net>
    INFO: Locale=en_US.UTF-8
    INFO: Converting filenames to UTF-8
    INFO: dvdauthor creating VTS
    STAT: Picking VTS 01
    STAT: Processing /media/usb_disk/movie/movie/movie_menu2_0.mpg...
    STAT: VOBU 64 at 2MB, 1 PGCSS
    INFO: Video pts = 0.238 .. 37.758
    INFO: Audio[0] pts = 0.238 .. 38.062
    INFO: Audio[32] pts = 0.238 .. 0.238
    STAT: VOBU 79 at 3MB, 1 PGCS
    INFO: Generating VTSM with the following video attributes:
    INFO: MPEG version: mpeg2
    INFO: TV standard: pal
    INFO: Aspect ratio: 4:3
    INFO: Resolution: 720x576
    INFO: Audio ch 0 format: ac3/2ch, 48khz drc
    STAT: Processing /usr/share/devede/base_pal.mpg...
    INFO: Video pts = 0.238 .. 1.198
    INFO: Audio[8] pts = 0.238 .. 0.406
    STAT: VOBU 2 at 0MB, 1 PGCS
    INFO: Generating VTS with the following video attributes:
    INFO: Audio ch 0 format: mp2/2ch, 48khz 20bps
    STAT: fi xed 79 VOBUS
    STAT: fixed 2 VOBUS
    STAT: Picking VTS 02
    STAT: Processing /usr/share/devede/base_pal_wide.mpg...
    INFO: Aspect ratio: 16:9
    STAT: Processing /media/usb_disk/movie/movie/movie_01_01.mpg...
    STAT: VOBU 14416 at 1648MB, 1 PGCSS
    INFO: Video pts = 0.238 .. 6920.558
    INFO: Audio[0] pts = 0.238 .. 6920.398
    STAT: VOBU 14418 at 1648MB, 1 PGCS
    STAT: fixed 2 VOBUS
    STAT: fixed 14418 VOBUS                   Deleting movie_??_??.mpg
    Trying to delete /media/usb_disk/movie/movie/movie_01_01.mpg
    delete menu
    Launching program:  mkisofs -dvd-video -V DVDVIDEO -v -o /media/usb_disk/movie/movie/movie.iso /media/usb_disk/movie/movie/movie
    elemento:  /usr/bin
    I: -input-charset not specified, using utf-8 (detected in locale settings)
    genisoimage 1.1.9 (Linux)
    Scanning /media/usb_disk/movie/movie/movie
    Scanning /media/usb_disk/movie/movie/movie/AUDIO_TS
    Scanning /media/usb_disk/movie/movie/movie/VIDEO_TS
    Writing:   Initial Padblock                        Start Block 0
    Done with: Initial Padblock                        Block(s)    16
    Writing:   Primary Volume Descriptor               Start Block 16
    Done with: Primary Volume Descriptor               Block(s)    1
    Writing:   End Volume Descriptor                   Start Block 17
    Done with: End Volume Descriptor                   Block(s)    1
    Writing:   UDF volume recognition area             Start Block 18
    Done with: UDF volume recognition area             Block(s)    3
    Writing:   Version block                           Start Block 21
    Done with: Version block                           Block(s)    1
    Writing:   UDF pad to sector 32                    Start Block 22
    Done with: UDF pad to sector 32                    Block(s)    10
    Writing:   UDF main seq                            Start Block 32
    Done with: UDF main seq                            Block(s)    16
    Writing:   UDF second seq                          Start Block 48
    Done with: UDF second seq                          Block(s)    16
    Writing:   UDF integ seq                           Start Block 64
    Done with: UDF integ seq                           Block(s)    2
    Writing:   UDF pad to sector 256                   Start Block 66
    Done with: UDF pad to sector 256                   Block(s)    190
    Writing:   UDF Anchor volume                       Start Block 256
    Done with: UDF Anchor volume                       Block(s)    1
    Writing:   UDF file set                            Start Block 257
    Done with: UDF file set                            Block(s)    2
    Writing:   UDF directory tree                      Start Block 259
    Done with: UDF directory tree                      Block(s)    6
    Writing:   UDF file entries                        Start Block 265
    Done with: UDF file entries                        Block(s)    12
    Writing:   Path table                              Start Block 277
    Done with: Path table                              Block(s)    4
    Writing:   Directory tree                          Start Block 281
    Done with: Directory tree                          Block(s)    3
    Writing:   Directory tree cleanup                  Start Block 284
    Done with: Directory tree cleanup                  Block(s)    0
    Writing:   The File(s)                             Start Block 284
      0.59% done, estimate finish Wed Dec 26 23:18:35 2012
      1.18% done, estimate finish Wed Dec 26 23:18:35 2012
      1.77% done, estimate finish Wed Dec 26 23:18:35 2012
      2.36% done, estimate finish Wed Dec 26 23:18:35 2012
      2.95% done, estimate finish Wed Dec 26 23:19:08 2012
      3.55% done, estimate finish Wed Dec 26 23:19:03 2012
      4.14% done, estimate finish Wed Dec 26 23:18:59 2012
      4.73% done, estimate finish Wed Dec 26 23:18:56 2012
      5.32% done, estimate finish Wed Dec 26 23:18:53 2012
      5.91% done, estimate finish Wed Dec 26 23:18:51 2012
      6.50% done, estimate finish Wed Dec 26 23:18:50 2012
      7.09% done, estimate finish Wed Dec 26 23:18:49 2012
      7.68% done, estimate finish Wed Dec 26 23:18:48 2012
      8.27% done, estimate finish Wed Dec 26 23:18:59 2012
      8.86% done, estimate finish Wed Dec 26 23:18:57 2012
      9.45% done, estimate finish Wed Dec 26 23:18:56 2012
     10.04% done, estimate finish Wed Dec 26 23:18:54 2012
     10.64% done, estimate finish Wed Dec 26 23:18:53 2012
     11.23% done, estimate finish Wed Dec 26 23:18:52 2012
     11.82% done, estimate finish Wed Dec 26 23:18:51 2012
     12.41% done, estimate finish Wed Dec 26 23:18:51 2012
     13.00% done, estimate finish Wed Dec 26 23:18:50 2012
     13.59% done, estimate finish Wed Dec 26 23:18:57 2012
     14.18% done, estimate finish Wed Dec 26 23:18:56 2012
     14.77% done, estimate finish Wed Dec 26 23:18:55 2012
     15.36% done, estimate finish Wed Dec 26 23:18:54 2012
     15.95% done, estimate finish Wed Dec 26 23:18:53 2012
     16.54% done, estimate finish Wed Dec 26 23:18:53 2012
     17.13% done, estimate finish Wed Dec 26 23:18:52 2012
     17.73% done, estimate finish Wed Dec 26 23:18:51 2012
     18.32% done, estimate finish Wed Dec 26 23:18:56 2012
     18.91% done, estimate finish Wed Dec 26 23:18:56 2012
     19.50% done, estimate finish Wed Dec 26 23:18:55 2012
     20.09% done, estimate finish Wed Dec 26 23:18:54 2012
     20.68% done, estimate finish Wed Dec 26 23:18:54 2012
     21.27% done, estimate finish Wed Dec 26 23:18:53 2012
     21.86% done, estimate finish Wed Dec 26 23:18:53 2012
     22.45% done, estimate finish Wed Dec 26 23:18:52 2012
     23.04% done, estimate finish Wed Dec 26 23:18:52 2012
     23.63% done, estimate finish Wed Dec 26 23:18:56 2012
     24.22% done, estimate finish Wed Dec 26 23:18:55 2012
     24.82% done, estimate finish Wed Dec 26 23:18:55 2012
     25.41% done, estimate finish Wed Dec 26 23:18:54 2012
     26.00% done, estimate finish Wed Dec 26 23:18:54 2012
     26.59% done, estimate finish Wed Dec 26 23:18:53 2012
     27.18% done, estimate finish Wed Dec 26 23:18:53 2012
     27.77% done, estimate finish Wed Dec 26 23:18:53 2012
     28.36% done, estimate finish Wed Dec 26 23:18:52 2012
     28.95% done, estimate finish Wed Dec 26 23:18:55 2012
     29.54% done, estimate finish Wed Dec 26 23:18:55 2012
     30.13% done, estimate finish Wed Dec 26 23:18:54 2012
     30.72% done, estimate finish Wed Dec 26 23:18:54 2012
     31.31% done, estimate finish Wed Dec 26 23:18:54 2012
     31.91% done, estimate finish Wed Dec 26 23:18:53 2012
     32.50% done, estimate finish Wed Dec 26 23:18:53 2012
     33.09% done, estimate finish Wed Dec 26 23:18:53 2012
     33.68% done, estimate finish Wed Dec 26 23:18:55 2012
     34.27% done, estimate finish Wed Dec 26 23:18:55 2012
     34.86% done, estimate finish Wed Dec 26 23:18:55 2012
     35.45% done, estimate finish Wed Dec 26 23:18:54 2012
     36.04% done, estimate finish Wed Dec 26 23:18:54 2012
     36.63% done, estimate finish Wed Dec 26 23:18:54 2012
     37.22% done, estimate finish Wed Dec 26 23:18:53 2012
     37.81% done, estimate finish Wed Dec 26 23:18:53 2012
     38.40% done, estimate finish Wed Dec 26 23:18:53 2012
     39.00% done, estimate finish Wed Dec 26 23:18:55 2012
     39.59% done, estimate finish Wed Dec 26 23:18:55 2012
     40.18% done, estimate finish Wed Dec 26 23:18:54 2012
     40.77% done, estimate finish Wed Dec 26 23:18:54 2012
     41.36% done, estimate finish Wed Dec 26 23:18:54 2012
     41.95% done, estimate finish Wed Dec 26 23:18:54 2012
     42.54% done, estimate finish Wed Dec 26 23:18:53 2012
     43.13% done, estimate finish Wed Dec 26 23:18:53 2012
     43.72% done, estimate finish Wed Dec 26 23:18:53 2012
     44.31% done, estimate finish Wed Dec 26 23:18:55 2012
     44.90% done, estimate finish Wed Dec 26 23:18:55 2012
     45.49% done, estimate finish Wed Dec 26 23:18:54 2012
     46.09% done, estimate finish Wed Dec 26 23:18:54 2012
     46.68% done, estimate finish Wed Dec 26 23:18:54 2012
     47.27% done, estimate finish Wed Dec 26 23:18:54 2012
     47.86% done, estimate finish Wed Dec 26 23:18:53 2012
     48.45% done, estimate finish Wed Dec 26 23:18:53 2012
     49.04% done, estimate finish Wed Dec 26 23:18:55 2012
     49.63% done, estimate finish Wed Dec 26 23:18:55 2012
     50.22% done, estimate finish Wed Dec 26 23:18:54 2012
     50.81% done, estimate finish Wed Dec 26 23:18:54 2012
     51.40% done, estimate finish Wed Dec 26 23:18:54 2012
     51.99% done, estimate finish Wed Dec 26 23:18:54 2012
     52.58% done, estimate finish Wed Dec 26 23:18:54 2012
     53.18% done, estimate finish Wed Dec 26 23:18:53 2012
     53.77% done, estimate finish Wed Dec 26 23:18:53 2012
     54.36% done, estimate finish Wed Dec 26 23:18:55 2012
     54.95% done, estimate finish Wed Dec 26 23:18:55 2012
     55.54% done, estimate finish Wed Dec 26 23:18:54 2012
     56.13% done, estimate finish Wed Dec 26 23:18:54 2012
     56.72% done, estimate finish Wed Dec 26 23:18:54 2012
     57.31% done, estimate finish Wed Dec 26 23:18:54 2012
     57.90% done, estimate finish Wed Dec 26 23:18:53 2012
     58.49% done, estimate finish Wed Dec 26 23:18:53 2012
     59.08% done, estimate finish Wed Dec 26 23:18:55 2012
     59.67% done, estimate finish Wed Dec 26 23:18:55 2012
     60.27% done, estimate finish Wed Dec 26 23:18:54 2012
     60.86% done, estimate finish Wed Dec 26 23:18:54 2012
     61.45% done, estimate finish Wed Dec 26 23:18:54 2012
     62.04% done, estimate finish Wed Dec 26 23:18:54 2012
     62.63% done, estimate finish Wed Dec 26 23:18:54 2012
     63.22% done, estimate finish Wed Dec 26 23:18:53 2012
     63.81% done, estimate finish Wed Dec 26 23:18:53 2012
     64.40% done, estimate finish Wed Dec 26 23:18:55 2012
     64.99% done, estimate finish Wed Dec 26 23:18:55 2012
     65.58% done, estimate finish Wed Dec 26 23:18:54 2012
     66.17% done, estimate finish Wed Dec 26 23:18:54 2012
     66.76% done, estimate finish Wed Dec 26 23:18:54 2012
     67.36% done, estimate finish Wed Dec 26 23:18:54 2012
     67.95% done, estimate finish Wed Dec 26 23:18:54 2012
     68.54% done, estimate finish Wed Dec 26 23:18:53 2012
     69.13% done, estimate finish Wed Dec 26 23:18:55 2012
     69.72% done, estimate finish Wed Dec 26 23:18:55 2012
     70.31% done, estimate finish Wed Dec 26 23:18:54 2012
     70.90% done, estimate finish Wed Dec 26 23:18:54 2012
     71.49% done, estimate finish Wed Dec 26 23:18:54 2012
     72.08% done, estimate finish Wed Dec 26 23:18:54 2012
     72.67% done, estimate finish Wed Dec 26 23:18:54 2012
     73.26% done, estimate finish Wed Dec 26 23:18:55 2012
     73.85% done, estimate finish Wed Dec 26 23:18:55 2012
     74.45% done, estimate finish Wed Dec 26 23:18:55 2012
     75.04% done, estimate finish Wed Dec 26 23:18:54 2012
     75.63% done, estimate finish Wed Dec 26 23:18:54 2012
     76.22% done, estimate finish Wed Dec 26 23:18:54 2012
     76.81% done, estimate finish Wed Dec 26 23:18:54 2012
     77.40% done, estimate finish Wed Dec 26 23:18:55 2012
     77.99% done, estimate finish Wed Dec 26 23:18:55 2012
     78.58% done, estimate finish Wed Dec 26 23:18:55 2012
     79.17% done, estimate finish Wed Dec 26 23:18:55 2012
     79.76% done, estimate finish Wed Dec 26 23:18:55 2012
     80.35% done, estimate finish Wed Dec 26 23:18:54 2012
     80.94% done, estimate finish Wed Dec 26 23:18:54 2012
     81.54% done, estimate finish Wed Dec 26 23:18:55 2012
     82.13% done, estimate finish Wed Dec 26 23:18:55 2012
     82.72% done, estimate finish Wed Dec 26 23:18:55 2012
     83.31% done, estimate finish Wed Dec 26 23:18:55 2012
     83.90% done, estimate finish Wed Dec 26 23:18:55 2012
     84.49% done, estimate finish Wed Dec 26 23:18:55 2012
     85.08% done, estimate finish Wed Dec 26 23:18:54 2012
     85.67% done, estimate finish Wed Dec 26 23:18:54 2012
     86.26% done, estimate finish Wed Dec 26 23:18:55 2012
     86.85% done, estimate finish Wed Dec 26 23:18:55 2012
     87.44% done, estimate finish Wed Dec 26 23:18:55 2012
     88.03% done, estimate finish Wed Dec 26 23:18:55 2012
     88.63% done, estimate finish Wed Dec 26 23:18:55 2012
     89.22% done, estimate finish Wed Dec 26 23:18:55 2012
     89.81% done, estimate finish Wed Dec 26 23:18:55 2012
     90.40% done, estimate finish Wed Dec 26 23:18:56 2012
     90.99% done, estimate finish Wed Dec 26 23:18:55 2012
     91.58% done, estimate finish Wed Dec 26 23:18:55 2012
     92.17% done, estimate finish Wed Dec 26 23:18:55 2012
     92.76% done, estimate finish Wed Dec 26 23:18:55 2012
     93.35% done, estimate finish Wed Dec 26 23:18:55 2012
     93.94% done, estimate finish Wed Dec 26 23:18:55 2012
     94.53% done, estimate finish Wed Dec 26 23:18:56 2012
     95.12% done, estimate finish Wed Dec 26 23:18:56 2012
     95.72% done, estimate finish Wed Dec 26 23:18:55 2012
     96.31% done, estimate finish Wed Dec 26 23:18:55 2012
     96.90% done, estimate finish Wed Dec 26 23:18:55 2012
     97.49% done, estimate finish Wed Dec 26 23:18:55 2012
     98.08% done, estimate finish Wed Dec 26 23:18:55 2012
     98.67% done, estimate finish Wed Dec 26 23:18:56 2012
     99.26% done, estimate finish Wed Dec 26 23:18:56 2012
     99.85% done, estimate finish Wed Dec 26 23:18:56 2012
     intento borrar
    Creating window /usr/share/devede/wend_dialog.ui
    /home/user1/
    Exiting
    Have a nice day
    Looking for the ffmpeg line in this successful log file, I find it mentioned, but no mention of the error "unrecognized option".
    Looking for that 'vf' option, I do see it in the log file above, but only in reference (I think) to mencoder.
    Launching program:  mencoder ... -vf scale=720:576,harddup ...
    So, I'm still confused - but - at least it's working now.
    My recommendation?
    DO NOT USE the linuxtech repositories for installing DeVeDe!
    Here's how I had installed the buggy DeVeDe using the linuxtech repository (for 64-bit Centos 6):
    DeVeDe installation (linuxtech method):
    0. $ sudo yum erase dvdauthor vcdimager mencoder devede libvcdinfo mplayer ffmpeg
    1. Add the linuxtech repo to /etc/yum.repos.d using steps 2 & 3 below
    2. $ cd /etc/yum.repos.d/
    3. $ sudo wget http://pkgrepo.linuxtech.net/el6/testing/linuxtech.repo
    4. This linuxtech.repo file has the 'linuxtech-release' repo enabled by default.
    5. Since mixing repos is bad, disable linuxtech-release using step 6 below
    6. sudo vi /etc/yum.repos.d/linuxtech.repo ==> Change: linuxtech-release 'enabled=1' to 'enabled=0'
    7. Then see if devede is available:
    8. $ yum --enablerepo=linuxtech-testing info devede
    9. To install devede, [temporarily] enable the 'linuxtech-release' repo for dependencies:
    10. $ yum --enablerepo=linuxtech-testing --enablerepo=linuxtech-release install devede
    11. If this reports dependencies of mplayer and mencoder, install them from elsewhere; then repeat step 10
    12. $ which devede ==> should report /usr/bin/devede & it will show up in your menus
    The problem was that the resulting DeVeDe failed EVERY time with the error about the -fv option.
    Luckily there was another repository for DeVeDe, found in pbone, so this is the method that I used that worked:
    DeVeDe installation (PBone method):
    1. http://pbone.net -> advanced search -> CentOS 6, RHEL 6 and Scientific Linux 6 -> devede ==> failed
    2. http://pbone.net -> advanced search -> add Fedora 12 and 13 ==> worked
    3. Downloaded devede-3.16.9-1.fc13.src.rpm
    4. $ rpmbuild --rebuild devede-3.16.9-1.fc13.src.rpm
    5. $ ls /home/USER/rpmbuild/RPMS/noarch/devede-3.16.9-1.el6.noarch.rpm
    6. $ cd /home/USER/rpmbuild/RPMS/noarch/
    7. $ sudo rpm -ivh ./devede-3.16.9-1.el6.noarch.rpm ==> reported 4 dependencies which are fixed in the next step (plus ffmpeg):
    8. $ sudo yum --enablerepo=rpmforge install dvdauthor mencoder mplayer vcdimager ffmpeg
    9. $ sudo rpm -ivh ./devede-3.16.9-1.el6.noarch.rpm
    10. $ which devede ==> should report /usr/bin/devede & it will show up in your menus
    In summary, whatever combination of DeVeDe 3.21.0 from linuxtech plus rpmforge (mencoder & ffmpeg) fails EVERY TIME; but, the DeVeDe 3.16.9 from pbone plus the same rpmforge tools (mencoder SVN-r31628-4.4.5 & ffmpeg 0.6.5 in particular) works just fine on the exact same files.
    Here's my recommendation:
    1. DO NOT install DeVeDe 3.21.0 from the linuxtech repository!
    2. Instead, install DeVeDe 3.16.9 from a source RPM (found at pbone) built for Fedora!
  7. Update.
    I spoke with the maintainer of the linuxtech-testing repository (listed in the "rpm -qi devede" command)who reproduced the problem - and - as a result - he removed the devede package from the repository to prevent others from having the same issues.
    The problem is that the ffmpeg program that worked with the older DeVeDe 3.16.9 hasn't been updated to work with the newer DeVeDe 3.21.0 which his repository had.
    So his repository had the new DeVeDe 3.21.0 but the old ffmpeg that only worked with DeVeDe 3.16.9.
    As ffmpeg affects many other programs, he opted to remove DeVeDe 3.21.0 wholly from the repository.
    He pointed me to this thread for details.
    It turns out that most ffmpegs are the older version:
    $ yum --noplugins --showduplicates --enablerepo \* --disablerepo c6-media,\*-source,\*debug\* provides "*/ffmpeg"
    REPORTS: linuxtech-release, naulinux-school, nux-dextop, rpmforge & ATrpms
    Apparently only the ATrpms version is the newer one - but it would be folly to mix repositories if you don't absolutely need it.
