i am using virtualdub in a screen capture programming project.
now, i was sure i had vlc or kmplayer play avisynth scripts, but all they do is present a blank screen and flicker. anyway, so i decide to just stick with vdub. but so far i can't find anything about a repeat. however, and unfortunately, i can't use the latest versions because they re-create each "view" window's HDC/Handle and my screen capture app looses its connection bc of it.
if you want to know how to determine if your version re-creates the hdc, just scroll all the way to the right or press Ctrl+cursor-right key. if your view window is gray, then your ver has the hdc problem and won't work for me.
i am currently using virtualdub-MPEDG2 1.6.15 since it keeps its HDC, indefinately. f5 will only play once.
thank you for all solutions.
Results 1 to 1 of 1
Area repeat with virtualdub
By zwobot in forum EditingReplies: 3Last Post: 18th Nov 2012, 19:36 -
Sony DVP-SR200P -- Playing CDs In Repeat Mode Without a TV
By maico996 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Jun 2012, 15:57 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
virtualdub: Cutting video in batch mode?
By zzyzx2 in forum EditingReplies: 2Last Post: 21st May 2010, 15:18 -
What is Batch mode editing in Virtualdub?
By gargoyle_xlvii in forum EditingReplies: 4Last Post: 22nd Feb 2008, 14:38
