Page 2 of 2
FirstFirst 1 2
Results 31 to 40 of 40
  1. I would resize the clip to 720x480, encode at 25 fps progressive, then use DgPulldown to add 3:2:3:2:2 pulldown flags. The other option is to resize to 720x480, AssumeFPS(24000,1001), and encode with regular 3:2 pulldown flags. But that will require that you slow the audio down too.
  2. Originally Posted by jagabo View Post
    I would resize the clip to 720x480, encode at 25 fps, then use DgPulldown to add 3:2:3:2:2 pulldown flags.
    Nice, thanks jagabo.
  3. Note, I added another option.
  4. Originally Posted by jagabo View Post
    I'll try both ways and see which one works better. Thanks again.
  5. Oh, I forgot to add that the MPEG 2 encoding should be flagged as 16:9.
  6. Yet ANOTHER question about resizing. (Again, I assume continuing this thread is better than starting multiple threads).
    I have a 1280x720 avi file that I want to resize and convert to MPEG 2 with HC Encoder.
    This is what I thought would work well:
    AvCSource("C:\video.dga")
    Spline36Resize(720,480)
    Colormatrix(mode="rec.709->rec.601")
    So, veterans, is this a good script?
  7. AVCSource is depreciated, it can have decoding errors other problems, use another source filter like FFMS2
    Typically you add clamp=0 for colormatrix (otherwise it will clip Y' 0-15, 236-255)
    Also is this 1280x720p23.976 or some other frame rate ?
  8. Originally Posted by poisondeathray View Post
    yes its 23.976 fps
    As for the Spline36Resize(720,480), is that an acceptable resize?
  9. Originally Posted by Radio Radio View Post
    yes its 23.976 fps
    Yes, for NTSC DVD . Encode it with 16:9 flags
  10. Originally Posted by poisondeathray View Post
    yes its 23.976 fps
    Ok. Thanks for the help!
